2620-2621 maximum memory
s.kurian
hi,
can someone tell me the maximum memory supported in 2621 router.as i want to run ipsec,ipx and adsl the minimum required is 96 mb,but i checked maximum it supports is 64 mb.(2621 memory modules are 5v edo type the max it makes 32 while it require one with 64 in each slot)
regards
shaji
5 Replies 5
for the 2621, 64MB DRAM and 32MB Flash are the physical maximum. They won't support more memory. There are only 32MB DRAM modules available for the 2621, no 64MB DRAM modules.
Check out this link:
http://www.memoryx.net/2621.html
GP
s.kurian
hi,
In the cisco ios of 2620-2621 if you go to entreprise plus ipsec 56 of (T)i.e 12.2 (4T) based ios which supports my requrement of ipsec/ipx/adsl the memory mentioned is 96 mb and flash 32 mb.I agree in memory module of 2621 it clearly mentions the max is 32 mb based module of 5v edo dram any work around.
regards
shaji
I see what you mean, it says 96MB DRAM...
I´ll check if that is a mistake on the website.
Georg
Check the following link, it looks like the max DRAM on 26xx routers is 64MB, however the newer 26xxXM routers support up to 128MB.
http://www.cisco.com/en/US/products/hw/routers/ps259/prod_module_install_config_guide09186a008007e1fb.html#92535
Hi all,
you can order an upgrade to 96 MByte and you will get a new BootRom from Cisco. So the 262x will support 96 MByte.
regards
Sascha
