7206VXR and 2514's Problem's
tinvill
We have three seperate 2514's connected to our 7206VXR serial ports. In the past few days at random times during the day all three links will drop with "retry limit expired". We first thought the problem was the serial card in the 7206 so we switched serial ports to a different card still with no succes which has lead us to believe that the 2514's are the problem. Any help would be appreciated.
spremkumar
Level 9
Level 9
hi
u hve mentioned the retry limit has expired is it the keepalive retry limit or anything related to tht ?then do chek up the keepalive settings on both the sides.
btw whts the media whichs connecting the 2 routers ??
regds
I dont if it has anything to do with the keepalive retry because it has been working fine for the past 4 months and it just started doing this. We are using tactical Multi-channel radio equipment. Sort of like point to point wireless with alot less bandwidth. That is for two of the three links. The third one is connected via a multiplex device hard wired to each other.
can u post the configs of ur both sides routers ?
regds
