a problem of configuring a modem on aux port for exec dialin connectivity.
xbrio
a Cisco 2501.configration line this:
Current configuration:
version 11.0
service udp-small-servers
service tcp-small-servers
hostname Router
chat-script dialout ABORT ERROR BUSY "" "AT" OK "ATDT\T" TIMEOUT 45 CONNECT\c
interface Ethernet0
ip address 192.168.0.253 255.255.255.0
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
interface Async1
ip unnumbered Ethernet0
no ip directed-broadcast
encapsulation ppp
async default routing
async mode interactive
peer default ip address pool dialin_pool
no cdp enable
ppp authentication chap pap callin
ip local pool dialin_pool 192.168.0.100
ip route 0.0.0.0 0.0.0.0 Ethernet0
line con 0
line aux 0
script dialer dialout
modem InOut
autocommand ppp
transport input all
stopbits 1
rxspeed 38400
txspeed 38400
flowcontrol hardware
line vty 0 4
login
end
when callin use a terminal ,the state of async 1 like this:
Async1: Async protocol mode started for 192.168.0.100
Async1: Carrier dropped while interface starting up
%LINK-5-CHANGED: Interface Async1, changed state to reset
Async1: Async protocol mode stopped for 0.0.0.0
%LINK-3-UPDOWN: Interface Async1, changed state to down
%LINK-3-UPDOWN: Interface Async1, changed state to up
why?and what shall i do?
tepatel
When you call in using a terminal and because of "autocommand ppp" configured under the line 1, router will start ppp after successful modem connection. So you will not get Router> prompt at terminal after connection and since the terminal can't start PPP, the async interface will reset after timeout.
To fix this, you need to use "autoselect ppp" instead. So enter
autoselect ppp
under the line 1. That will give you Router> prompt in the terminal
makchitale
Level 6
Level 6
If you are trying an exec connection, remove the "autocommand ppp" from under the line aux 0 & add "autoselect ppp" instead. Need to see deb modem / deb ppp nego.
Thanks, Mak.
I have done.use autoselect ppp instead.but the Terminal stop at the prompt
connect 33600 and some strange letter,then modem disconnect.
what's wrong?
thank you.
Has this ever worked before for an exec dialin? The strange letter could be due to a speed mismatch...try changing the speed on the dialup side.
If you have enough memory, try upgrading to maybe 11.3 atleast from the present 11.0.
Thanks, Mak.
