C9500-16X DAD link, interface module selection ?
yuxiang zhou
HI
Can i using GLE-TE for DAD link purpose directly between two C9500-16X ?
Glad it as usefull, if your problem resolved, marks as resolved,
BB
7 Replies 7
balaji.bandi
yes you can use, the document never mentioned any kind of media for Dual Active Detection. as long as they are reachable should be good and directly connected.
BB
HI balaji.bandi,
Thanks reply.
I find some info in "High Availability Configuration Guide"
In the chapter Configuring StackWise Virtual Fast Hello Dual-Active-Detection Link, step3 it says:
Perform one the of the following depending on the switch that you are configuring.
If you are configuring a Cisco Catalyst 9500 Series Switch, use interface { TenGigabitEthernet | FortyGigabitEthernet } <interface>
If you are configuring a Cisco Catalyst 9500 Series High Performance Switch, use interface { HundredGigE | FortyGigabitEthernet | TwentyFiveGigE } <interface>
Example:
Device(config)#interface TenGigabitEthernet1/0/40
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-8/configuration_guide/ha/b_168_ha_9500_cg/b_168_ha_9500_cg_chapter_011.html
So, there is a possible not support GLC-TE ?
Agreed yor point, But if you have mGIG ports you can use GLC-T for 1 Gig, the port you have mentioned can not go less than 10Gig, (i have not seen eithernet GLC-T for 10G , there may be available in the market, not tested myself)
I will test DAD with 1GIG GLC-T with mGIG port on later week and post the results.
BB
Thank you for your support, hopefully get your good news soon!
here is test results :
SW1#show interfaces twentyFiveGigE 1/0/2
TwentyFiveGigE1/0/2 is up, line protocol is up (connected)
Hardware is Twenty Five Gigabit Ethernet, address is REMOIVED
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 10/100/1000BaseTX SFP
input flow-control is on, output flow-control is off
Last input 00:05:33, output never, output hang never
Last clearing of "show interface" counters 00:33:58
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
19 packets input, 8199 bytes, 0 no buffer
Received 18 broadcasts (18 multicasts)
0 watchdog, 18 multicast, 0 pause input
8 packets output, 4144 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
11 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
SW1#show interfaces twentyFiveGigE 2/0/2
TwentyFiveGigE2/0/2 is up, line protocol is up (connected)
Last input never, output 00:00:51, output hang never
2 packets input, 634 bytes, 0 no buffer
Received 1 broadcasts (1 multicasts)
0 watchdog, 1 multicast, 0 pause input
26 packets output, 10031 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
SW1#show stackwise-virtual dual-active-detection
Dual-Active-Detection Configuration:
Switch Dad port Status
1 TwentyFiveGigE1/0/2 up
2 TwentyFiveGigE2/0/2 up
SW1#show interfaces status | in connected
Twe1/0/2 connected 4094 a-full auto 10/100/1000BaseTX SFP
Twe2/0/2 connected 4094 a-full auto 10/100/1000BaseTX SFP
SW1#show run interface twentyFiveGigE 1/0/2
Building configuration...
Current configuration : 78 bytes
interface TwentyFiveGigE1/0/2
end
BB
HI balaji.bandi,
Thank you! Very appreciate your help !
BB
