Cisco 2950 Switch Redundant Power Supply Failure
JonathanUK
Level 3
Level 3
I've been upgrading two switches in my lab and have come across this error. It came up when I downloaded Cisco Network Assistant. The error hasn't come up on my other switch, at the moment its just plugged into a standard socket at home. Any help would be much appreaciated.
Thanks in advance Jonathan
Hello Jonathan,
are you actually using an RPS for your 2950 ? Can you explain a little bit more what exactly you were doing ?
GP
Hi GP
I simply had the 2950 connected to my laptop no RPS. The switch was just plugged into a normal floor socket. I then connected by CNA and the alarm came up.
Hello Jonathan,
I have the same problem on all my switches running IOS 12.1(13)...
Have you found any solution? I'm pretty sure it could be a bug!!!
Ruben
