Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 801 with Rtr track feature
dcristoni
i need to use Rtr track command in my 801 Isdn Router.
This feature was introduced in Cisco IOSĀ® Software Release 12.3(4)T but i don't be able to find this release for 801 Router.
Please let me known if release 12.3.9 or any other release support Rtr track feature in 801 Router.
irisrios
Level 6
Level 6
You may either look in the command reference guide or command lookup tool available on www.cisco.com/tac. It gives if the command is currently supported. Also you can check the release notes for 801 router and check for the required command support.
