If I want, the Router, to boot the IOS from for example tftp://192.168.0.1/NAME.xyz AND the Router should not load any configuration file, what do I have to type?
And... How does this work, because the router does not have a configured IP Interface, how can it fetch this file from tftp?
Listen: https://smarturl.it/CCRS9E25 Follow us: twitter.com/ciscochampions
With applications and users everywhere, the networks are now, more than ever, being tasked with delivering consistent protection while providing an exceptional user exper...
view more
Listen: https://smarturl.it/CCRS9E24 Follow us: https://twitter.com/CiscoChampion
Cisco Radio Aware Routing addresses several of the challenges faced when merging IP routing and radio communications in mobile networks, especially those exhibiti...
view more
Listen: https://smarturl.it/CCRS9E23 Follow us: https://twitter.com/CiscoChampion The Wi-Fi 6E Catalyst 9136 access point takes advantage of the 6-GHz band to produce a network that is more reliable and secure, with higher throughput, more ...
view more
When moving from OSPFv2 to OSPFv3, there are many changes in the format of the LSAs Type, but the most known changes are: IP prefix informations are no longer carried in Type-1 LSA and Type-2 LSA, new LSAs Type 8 and 9 are added to carry these prefixes.
L...
view more
