cisco switch trunk is not working
n.bokhar1
l have three cisco switches a 3850 core switch and two 2960x access switches
i have connected the both 2960x s to my 3850 via gbic-t ports
and i have configured a few vlans on my core switch with below configurations :
ip routing
vtp mode off
spann mode rapidpvst
spann vlan 10-180 root primary
vlan 10
vlan 20
vlan 80
int vlan 10
 ip add 10.1.1.1 255.255.255.0
int vlan 20
 ip add 10.1.2.1 255.255.255.0
int vlan 80
 ip add 10.1.8.1 255.255.255.0
int gig 1/0/6
 sw mode trunk
 sw trunk native vlan 80
 sw trunk allowed vlan 10-80
and configure boath my 2960s like this:
vtp mode off
vlan 10
vlan 20
vlan 80
int vlan 1
 shut
int vlan 80
 ip add 10.1.8.2&3 255.255.255.0
int gig 1/0/1
 sw mode trunk
but when i have ping only on one of the  switches to 10.1.8.1 the other one is not working
and i don't know what the hell is going on please help me
what did i do wrong ???
chrihussey
Not much to go on here, can you post the following information from the switch you cannot ping:
show interface g1/0/1 trunk
show interface g1/0/1 status
show spanning-tree root
show arp
sh int vlan714 status
show ip interface vlan 80
If you could also post from the 3850 core:
show interface trunk
show arp
show mac address-table interface g1/0/6 (or whatever is going to the unpingable switch)
Can the two 2960s ping each other?
I think your 3 Cisco 3850 are in stack, and you have like a triangle with the 2960X, right?
                    Cisco 3850 Stack
       Cisco 2960X   ----- Cisco 2960X
You could execute show ip int brief  and see if the interface vlan 80 is UP UP on the 3 switches. Probably the VLAN 80 is not applied or passing through.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
