12-08-2018 05:11 AM - edited 03-03-2019 08:57 AM
Is it possible to configure this router so that it transmits Ethernet over E1?
I've got VWIC-2MFT-G703, HWIC-4ESW modules and 2 GigabitEthernet ports.
Configuration of E1:
controller E1 0/0/0
framing NO-CRC4
channel-group 0 timeslots 1-31
When I configured E1, Serial 0/0/0 interface with HDLC encapsulation appeared.
What should I do next to connect FE or GE to WAN (Serial, E1)?
12-09-2018 01:02 PM
You can not connect either FE or GE interfaces to an E1 interface. The E1 is a serial interface and can support serial protocols but can not support the Ethernet protocol. The connectors used may look the same but they can not interconnect FE or GE to E1.
Rick
12-09-2018 10:20 PM
Probably my question wasn't clear enough.
What I try to get is to encapsulate Ethernet-packet into E1 structure.
12-09-2018 11:52 PM
12-12-2018 09:18 PM
12-13-2018 05:02 AM
You are quite welcome. These communities are excellent places to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
