Configuring Multicast for Ghost Applications
Scott Fella
I have a 6509 with (2) L3 modules at the core and 3508's that connect to the 6509 for the access layer. I'm using 3512, 3524, and 3548 for my access layer switches. The network has about 17 VLANS configured. Each 3508 and the 3500 that connect are one vlan. However specific ports are configured for other vlans.... example... voice, wireless, printers...etc.
I want to enable multicast because we are using Ghost throughout the network. The question I have, is on the 6509, do I just enable IGMP Snooping and GMRP? Global commands and no port commands?
On the 3500's, is it also a global command? Configure CGMP and that's it?
Any input on what commands I should implement on the 6509 and in the 3500's or how I should configure the switches would help.
Thanks!
-Scott
10 Replies 10
Prashanth Krishnappa
Enable IGMP snooping on the 6500, CGMP on the XLs. Configure Multicast routing on the MSFCs, enable PIM/CGMP on the VLAN interfaces. Make sure the TTL on the multicast server is set to something more than number of VLANs you have
The following page on CCO should be useful as well
http://www.cisco.com/warp/public/473/22.html
-Prashanth
milan.kulik
Level 10
Level 10
I've spent a lot of time fixing Ghost multicast problem and this is my solution:
1) set a mutlicast storm control on the port the Ghost server (multicast source) is connected to the network. I'm using 2000 rising and 1500
falling thresholds. This decreases the absolute number of multicasts flooded to the network.
2) enable IGMP snooping on switches which are IGMP-snooping enable (Cat6500, 2950) and set CGMP enable on switches which are not
(Cat4000). On Cat3500 and 2900 CGMP is enabled by default.
3) configure
ip pim sparse-mode
ip cgmp
on your router LAN port.
Don't use CGMP fast-leave if you're using HSRP in your network (address conflict).
The way this scenario works:
At the moment wokstation joins a multicast group it sends a IGMP join message. IGMP-enable switches detects it and they send multicast
traffic to appropriate ports only then. IGMP-not-enabled switches receive this info through CGMP - a router "translating" from IGMP to CGMP
is necessary.
There are some minor problems remaining (if the workstation joins several multicast groups rapidly it takes some time to detect it and
aproximately 30 sec multicast storm apears, e.g.) but generally this scenario works.
The above description is very rough, for detailed info see:
http://www.cisco.com/warp/public/473/38.html
http://service4.symantec.com/SUPPORT/ghost.nsf/docid/1999033015222425
A good news in the end: There is a new Ghost version available which should be much more flexible and user friendly regarding
unicats/multicasts options.
Hope to help,
Milan
Okay... I understand better.
On the 6509, I will configure IGMP-Snooping that is all
On the 3500's I will configure CGMP that is all
On the port where the Ghost server is connected, I have to use a multicast storm control
Since I have both MSFC on the 6509 load-balancing vlans (odds on one / evens on the other), I should not configure CGMP fast-leave. On the MSFC's, I have to configure (this would be my router LAN port corect?:
ip pim sparse-mode
ip cgmp
This is it......correct?
Just making sure and thanks for the reply's!
-Scott
You don't have to use multicast storm control on the port where the Ghost server is connected but I would recommend it as a insurance for the case CGMP or IGMP mechanism fails.
To be correct, this is a solution for running Ghost in one VLAN and preventing multicast storms in it.
If you want to run Ghost application with Ghost server in one VLAN and clients in several VLANs, you should configure multicast routing which is much more complex and I'm not able to give an correct advice without your network detailed knowledge.
Milan
This is how the netowrk is set up.
6509 with 2 sup L3 at the core
3508 at each IDF that connects to the 6509 gig module. Each IDF is configured for it's own vlan. (IDF 2-Vlan-2 ....... IDF 16-Vlan 16)
Connected to the 3508 are 3512, 3524, 3524-PWR, and 3548. However, switch ports might be configured for another vlan (voice vlan, wireless vlan, printer vlan). Switches are not daisy chained, each has a seperate fiber going to the 3508.
I do have HSRP configured in the 6509, odd vlans active on one of the MSFC's and even vlans avtive on the other MSFC's.
I do wnat to run Ghost in one vlan and clients will be in all other vlans.
6509 L2
#igmp
set igmp enable
------snip------
Session 15 Example
ip subnet-zero
ip multicast-routing
ip dvmrp route-limit 20000
ip cef
ip dhcp-server 10.2.0.9
ipx routing 0030.b639.2bf8
cns event-service server
!interface Vlan1
ip address 10.2.100.2 255.255.255.0
ip helper-address 10.2.0.9
no ip redirects
no ip directed-broadcast
no ip mroute-cache
standby 1 priority 105 preempt
standby 1 ip 10.2.100.1
ip pim sparse-dense-mode
interface Vlan2
ip address 10.2.2.2 255.255.255.0
no ip redirects
ipx encapsulation SAP
ipx network 230F0002
standby 2 priority 110 preempt
standby 2 ip 10.2.2.1
------snip------
Let me know what other configurations I need to do. I have not configured any of the 3500's yet.
-Scott
Should I configure the interfaces with:
or
ip pim sparse-mode
-Scott
Sparse-dense mode will almost always do the right thing, and is the preferred choice.
/Chris Thomas, UCLA ATS
Thanks! I will give it a shot.
-Scott
You said to set a multicast storm control on the port the Ghost server is connected to. The server is connected to to the 6509 port 7/4. So I did a SET PORT BROADCAST 7/4 75%..... does this look okay?
Thanks!
-Scott
I would use set port broadcast 7/4 25 multicast enable or something like that - I'm not using Cat6500 in my network but I suppose it might work. But be careful and check if the filter really works. There is a note in Cat6000 documentation saying that it's possible to filter multicasts on Gigabit ports - so I'm not sure if it works on FastEthernet ports (it doesn't on Cat4000, e.g.).
What I'm using is following:
interface FastEthernet0/20
description Ghost
port storm-control broadcast action filter
port storm-control broadcast threshold rising 2500 falling 1500
port storm-control multicast action filter
port storm-control multicast threshold rising 3000 falling 2000
on Cat3524. It enables me to define the exact number of multicast per second allowed to enter the network from the Ghost server port.
Regarding your router config:
you should use ip multicast-routing global configuration command to enable multicast routing from one VLAN to the others.
But I didn't configure it personally so I don't know details what else is necessary. The only I recommend looking to your config is to check if your "no ip mroute-cache" for VLAN1 is correct.
I'm also not sure that the sparse-dense mode is optimal - the sparse mode prevents multicast flooding in strict way.
Milan
