DHCP problem on Catalyst 2960
santipongv
Client PC is unable to obtain DHCP IP address from Cat-2960 (cisco WS-C2960-24TT-L). Any advice would be greatly appreciated.
---Portfast is enabled on all ports---
ip dhcp limited-broadcast-address
ip dhcp excluded-address 192.168.1.1 192.168.1.6
ip dhcp pool XXX
network 192.168.1.0 255.255.255.224
dns-server 199.45.32.38 151.197.0.38
domain-name XXX.com
default-router 192.168.1.2
netbios-node-type h-node
lease 30
Switch-2960#sh ip dhcp binding
IP address Client-ID/ Lease expiration Type
Hardware address
Switch-2960#sh ip dhcp server stat
Memory usage 1390
Address pools 1
Database agents 0
Automatic bindings 0
Manual bindings 0
Expired bindings 0
Malformed messages 0
Message Received
BOOTREQUEST 0
DHCPDISCOVER 0
DHCPREQUEST 0
DHCPDECLINE 0
DHCPRELEASE 0
DHCPINFORM 0
Message Sent
BOOTREPLY 0
DHCPOFFER 0
DHCPACK 0
DHCPNAK 0
Santi
glen.grant
Make sure you apply the "switchport host" command to all client ports and see if that helps . Are these clients all on the same subnet (vlan) ???
