ESX and VMWARE - LACP and Cisco 6506
dhoule
Hello Everyone,
As anyone been able to configure ESX 2.5.1 to use Etherchannel?
VMWARE’s documentation claims that ESX supports LACP to create an EtherChannel. As per VM support I have configured my ESX server correctly and it should use LACP establish an Etherchannel. However on my switch, I see no evidence of LCAP traffic of connectivity via the port-channel. See below for output.
Has anyone here, in the cisco community, got this to work? If yes, would you please advise and share sample configuration.
Output
core-rtr#sh interfaces port-channel 1
Port-channel1 is up, line protocol is down (notconnect)
Hardware is EtherChannel, address is 0000.0000.0000 (bia 0000.0000.0000)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Auto-duplex, Auto-speed
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
Last clearing of "show interface" counters 4d23h
Input queue: 0/2000/3/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
20 packets input, 1360 bytes, 0 no buffer
Received 20 broadcasts (0 multicast)
0 runts, 4 giants, 0 throttles
4 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
32 packets output, 7017 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
_________________________________
core-rtr#show etherchannel 1 summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(SD) LACP Fa4/1(I) Fa4/3(I) Fa4/7(I)
core-rtr#show lacp 1 internal
Flags: S - Device is requesting Slow LACPDUs
F - Device is requesting Fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
Channel group 1
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Fa4/1 SA indep 32768 0x1 0x1001 0x401 0x7D
Fa4/3 SA indep 32768 0x1 0x1 0x403 0x7D
Fa4/7 SA indep 32768 0x1 0x1 0x407 0x7D
Note from Cisco’s docs: indep—Port is in an independent state (not bundled but able to switch data traffic. In this case, LACP is not running on the partner port).
core-rtr#sh lacp 1 neighbor
Channel group 1 neighbors
Partner's information:
LACP port Oper Port Port
Port Flags Priority Dev ID Age Key Number State
Fa4/1 SP 0 0000.0000.0000 678158s 0x0 0x0 0x0
Fa4/3 SP 0 0000.0000.0000 678158s 0x0 0x0 0x0
Fa4/7 SP 0 0000.0000.0000 678158s 0x0 0x0 0x0
mchin345
Level 6
Level 6
We will now include the commands necessary to configure LACP. The steps include the Cisco IOS Software and CatOS commands required. Pick the appropriate command depending on the software that is running on the switch.
http://www.cisco.com/warp/public/473/126.html
ToddWarren
Have you tried changing LACP on the ESX to be active, and not passive? I have encountered issues with other vendors implementation of LACP even though all documentation suggest ACTIVE-PASSIVE "should" work. I don't see partner state field in show lacp neigh??Sorry, I have no specific info on ESX configuration.
