Flexible Netflow has no Volume
A Stevens
Hi All,
I hope someone can shed some light on my problem :)
The Situation is as follow: We have a Cisco Switch  (WS-C3650-24TS) and configured netflowV9 on it.
It should export the cache every 60sec to the some collector ( we will use PRTG from Paessler).
The netflow is by the server where PRTG is running on, but somehow it has no volume see screenschot.
Paessler said this:
We did notice something very important in the Netflow Tester results.
The crucial point are the '-1' numbers at the end of each line.
The last number for each decoded flow is its volume. -1 is no volume at all.
So while the Netflow Tester (and PRTG as well) do get source & destination information, the traffic actually has no volume.
Thus the sensor stays grey, as it needs a volume to start working at al
l.
They say that they dont know the right configuration for every Vendor, so thats why I post it here.
The question is why the volume keeps on -1 and how to fix this
Here the netflow configuration of the Switch
>flow record ipv4_record
>match ipv4 protocol
>match ipv4 source address
>match ipv4 destination address
>match transport source-port
>match transport destination-port
>match interface input
>collect transport tcp flags
>collect interface output
>collect counter packets long
>collect counter bytes layer2 long
>flow exporter PRTG
>destination 172.16.x.x
>source Vlan101
>transport udp 2055
>flow monitor MAIN_MONITOR
>exporter PRTG
>cache timeout active 60
>record ipv4_record
>interface GigabitEthernet1/0/19
>ip flow monitor MAIN_MONITOR input
fbsdkernel
I've not configured this as such on a 3650, however, this is a snippet of the configuration I have used with PRTG and now with manageengine on a 7600 and an NPE-G2:-
mls aging long 64
mls aging normal 32
mls flow ip interface-full
mls flow ipv6 interface-full
mls nde sender version 5
mls sampling packet-based 1024 16000
ip flow-export source Loopback0
ip flow-export version 5 origin-as
ip flow-export destination (IP OF SMAPLER DEVICE HERE) 9996
interface GigabitEthernet1/1
 description Transit: provider name
 ip flow ingress
 mls netflow sampling
interface GigabitEthernet1/2
 description Core: Internal core link
 ip flow ingress
Hope this helps
James
Hi James,
Thanks for your reply, however I could not use the version 5 command and I could not get this working. But I decided to configure netflow on the 2921 router in front and it works.
Even if I make a own record-template with match and flow it works.
Notice I used the record netflow-original which the switch didnt have only the wireless template.
==Snip Switch ==
pco1-ven1-swi1(config-flow-monitor)#record ?
ipv4_record  User defined
wireless     Templates for Wireless Traffic
==Snip Switch END==
==Snip Router==
flow exporter PRTG
 source BVI101
 transport udp 9996
 exporter PRTG
==Snip Router END==
If there is anybody, that knows the cause of 'no volume sending within the netflow' , from a switch WS-C3650-24TS, or any other switch.
Let me know :)
Hi A Stevens. I have the exact sane problem here. What did you end up doing as a workaround exactly?
You said "Even if I make a own record-template with match and flow it works."
