help me,NM-30DM+NM-1CE1U+3600
jonathanjin
the problem is :if just one user is online, everything is ok,but when the 2nd user dialer in,the first user can't ping or access any computers(include the access server),but still connecting,if the second user disconnect the line,the first user can ping and access computers again.that's so strange,I use NM-30DM+NM-1CE1U+3661 or NM-30DM+NM-1CE1U+3640,the same result.I also upgraded the ios,even the newest one (is-mz.123-4.T.bin),also failed.
the current config is:
memory-size iomem 15
modem country mica china
ip subnet-zero
no ip finger
no ip domain-lookup
isdn switch-type primary-net5
controller E1 0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/1
interface Loopback0
ip address 192.168.0.1 255.255.255.0
interface Serial0/0:15
no ip address
encapsulation ppp
dialer pool-member 2
isdn incoming-voice modem
ppp authentication pap chap callin
interface Ethernet2/0
ip address 168.168.45.1 255.255.255.0
half-duplex
interface Group-Async1
ip unnumbered Loopback0
encapsulation ppp
load-interval 30
dialer in-band
async mode dedicated
no peer default ip address
group-range 33 62
interface Dialer2
encapsulation ppp
dialer pool 2
dialer idle-timeout 3600
dialer fast-idle 720
dialer-group 1
peer default ip address pool 3661
ip local pool 3661 168.168.45.110 168.168.45.150
ip classless
ip route 0.0.0.0 0.0.0.0 168.168.45.2
access-list 1 permit any
dialer-list 1 protocol ip list 1
line con 0
transport input none
line 33 62
exec-timeout 0 0
autoselect ppp
modem answer-timeout 120
modem Dialin
modem autoconfigure discovery
transport input all
flowcontrol hardware
line aux 0
line vty 0 4
password cisco
login
end
8 Replies 8
hbaerten
Level 4
Level 4
do you have this problem with analog dialin, isdn, or both?
Can you post a "debug ppp negotiation" of 2 users dialing in?
regards
Herbert
what happens if you put those two commands under your interface Group-Async1:
--> instead of no peer default ip address
async mode interactive
--> instead of async mode dedicated
GP
I have tried "peer default ip address pool 3661",but it is the same with "no peer default ip address",I will try "async mode dedicated",any suggestions else?
and for upstairs,I use debug ,but everthing seems ok,and both isdn&anlog meet the problem.after the second user dialer in,the first user can't ping ,I show the async interface,both the interface and its line protocol are up,and can see the route via "sho ip route" command,but just can't ping and access,help!
I have tried these two things,there all all useless,anything else?
mark-obrien
Level 4
Level 4
I would try eliminating the "ip unnumbered Loopback0" and the "no peer default ip address" commands from the group-async interface. All IP information should come from the Dialer interface instead of the physical interface.
Mark
Hello Everybody!
I don't know Where to send a question, so i chose to reply here, so sorry for disturbing!
My question is:
This is my routeur config:
ciradvxh#sho startup-config
Using 1953 out of 8046 bytes, uncompressed size = 3548 bytes
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service compress-config
hostname ciradvxh
boot system flash aaa0842.bin
no logging console
enable secret 5 $1$8mXg$jnx7w4j061Bwwpc2dyHm51
enable password vxhrnis
username IPSGUAD password 7 107D263036273B
ip subnet-zero
no ip source-route
ip inspect name fwr ftp
ip inspect name fwr h323
ip inspect name fwr realaudio
ip inspect name fwr smtp
ip inspect name fwr sqlnet
ip inspect name fwr streamworks
ip inspect name fwr tcp
ip inspect name fwr udp
no ip domain-lookup
no ip finger
isdn switch-type vn3
isdn tei-negotiation first-call
process-max-time 200
interface Ethernet0
description lan Cirad Vx Habitants
ip address 192.168.0.254 255.255.255.0
ip access-group 121 in
ip access-group 122 out
no ip directed-broadcast
ip nat inside
ip inspect fwr in
no cdp enable
interface BRI0
description Liaison NUMERIS
no ip address
encapsulation ppp
dialer pool-member 1
dialer pool-member 3
isdn send-alerting
no cdp enable
interface Dialer1
description MEDIASERV
ip address negotiated
ip access-group 123 out
ip nat outside
ip inspect fwr out
encapsulation ppp
no ip route-cache
no ip split-horizon
dialer remote-name REGGAE
dialer idle-timeout 90
dialer string 00590326464
dialer caller 00590326464
dialer hold-queue 30
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username ciradvxh password 7 1315111D5F5A
interface Dialer2
description connx SAV
ip address 11.17.0.2 255.255.0.0
encapsulation ppp
no ip split-horizon
dialer remote-name IPSGUAD
dialer idle-timeout 30
dialer string 00590894500
dialer caller 00596894500
dialer hold-queue 10
dialer pool 2
dialer-group 2
no cdp enable
ppp authentication chap
interface Dialer3
description Neufchateau
ip nat outside
encapsulation ppp
no ip route-cache
no ip split-horizon
dialer remote-name hpglp
dialer string 00590861785
dialer caller 00590861785
dialer pool 3
dialer-group 3
ppp pap sent-username pfo-vxh password 7 pfo46;
ip nat inside source list 121 interface Dialer1 overload
no ip http server
ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 11.17.0.0 255.255.0.0 Dialer2
ip route 97.142.0.0 255.255.0.0 Dialer2
ip route 212.155.143.0 255.255.255.0 Dialer1
ip route 213.188.0.0 255.255.0.0 Dialer1
access-list 121 permit ip any any log
access-list 121 permit ip 192.168.0.0 0.0.255.255 any log
access-list 121 deny ip any any log
access-list 122 permit ip any any log
access-list 122 permit ip 97.142.1.0 0.0.0.255 any log
access-list 122 permit icmp any any log
access-list 122 deny ip any any log
access-list 123 permit ip any any log
access-list 123 deny udp any any eq netbios-ns
access-list 123 deny udp any any eq netbios-dgm
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
dialer-list 3 protocol ip permit
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
exec-timeout 60 0
password vxhrnis
login
end
We recently added a server gateaway. Our ISDN line automaticaly connects and i don't
understand why! It was the same before we buy the server.
In French system, you pay each time it connects so, it's a problem for us. Can you help us
please to understand what happend in this traffic. btw: i've got a routeur cisco 803, but
the debug command only give me messages like this: Dial on demand packets/events debugging
is on! So i can't know who connects and when!
Thanks for your cooperation.
thanks first,i will "no ip address" in group-async1,but how to eliminate "no peer default ip address"?
Now that you mention it, it might go away immediately when you remove IP from the interface, with the "no ip address" command.
Mark
