How increase flash memory for cisco routers in GNS3?
er.maharaja.a
I have GNS3 simulator and I am trying to increase the flash memory. I've changed the memory in the GNS3 -> R1 -> Configure -> Memories and disks -> PCMCIA disk slot to 124 MiB.
I created a new topology and set the memory. Still it shows the same 8MiB (default).
How to fix it?
Raja
kaaftab
Level 4
Level 4
when you load the image there is an option of flash there you can set the value
********************Do rate Helpful links********************
yes.
you can change the size of PCMCIA Disk0. then formate the flash( R1# erash flash: ,)R1# formate flash:)
now you can check the flash using show flash: command .it should work
Fernand DOUBI
Hello!!
Can you use routers like 3725 and try to increase the memory in node configuration.
You can change the size of PCMCIA Disk0.
This kind of routers works for me.
