01-02-2006 11:16 PM - edited 03-03-2019 01:18 AM
Understand SUP720 only runs with C6K-9SLOT-FAN2.
How do I know whether the customer is using FAN1 or FAN2 now?
Is there any show command to see?
Or any sign on the fan?
Thanks in advance!
Solved! Go to Solution.
01-04-2006 03:28 PM
You should be able to tell by just looking at it.
My old FAN1 had the slot numbers 1 through 9 along one edge; a bar code sticker between numbers 1 and 2; and a Fan Status LED down by number 9.
My new FAN2 has all of the above, plus: WS-C6K-9SLOT-FAN2= written on it just under one of the thumbscrews and above number 1; FAN TRAY 2 written vertically in big letters above the handle, next to numbers 2 and 3; and a yellow label below the handle down between numbers 7 and 8 that says:
WARNING - THIS FAN TRAY IS DESIGNED TO BE USED WITH A 2500W OR LARGER POWER SUPPLY. DO NOT USE IT WITH THE 1000W OR 1300W POWER SUPPLIES. SYSTEM SHUTDOWN OR DAMAGE MAY OCCUR.
My guess is, when they made FAN1 they had no idea they would ever need to tell it apart from another fan tray, so they didn't bother to put any unique markings on it.
01-02-2006 11:31 PM
What does 'show environment' give you ?
Paresh.
01-03-2006 12:44 AM
I did not see the fan tray type in the output. :(
esw4> (enable) sh environment
Environmental Status (. = Pass, F = Fail, U = Unknown, N = Not Present)
PS1: . PS2: . PS1 Fan: . PS2 Fan: .
Chassis-Ser-EEPROM: . Fan: .
Clock(A/B): A Clock A: . Clock B: .
VTT1: . VTT2: . VTT3: .
esw4> (enable)
esw4> (enable)
esw4> (enable)
esw4> (enable) sh environment all
Intake Exhaust Device 1 Device 2
Slot Temperature Temperature Temperature Temperature
1 24C(50C,65C) 29C(60C,75C) 25C 30C
2 22C(50C,65C) 28C(60C,75C) 25C 31C
3 27C(50C,65C) 30C(60C,75C) 25C 27C
4 26C(50C,65C) 29C(60C,75C) 25C 26C
5 26C(50C,65C) 28C(60C,75C) 24C 26C
6 25C(50C,65C) 28C(60C,75C) 24C 27C
7 25C(50C,65C) 28C(60C,75C) 23C 26C
8 26C(50C,65C) 27C(60C,75C) 23C 25C
9 27C(50C,65C) 29C(60C,75C) 25C 27C
1 (Switch-Eng) 19C(50C,65C) 22C(60C,75C) N/A N/A
2 (Switch-Eng) 20C(50C,65C) 21C(60C,75C) N/A N/A
Chassis Modules
VTT1: 22C(85C,100C)
VTT2: 22C(85C,100C)
VTT3: 26C(85C,100C)
PS1 Capacity: 1153.32 Watts (27.46 Amps @42V)
PS2 Capacity: 1153.32 Watts (27.46 Amps @42V)
PS Configuration : PS1 and PS2 in Redundant Configuration.
Total Power Available: 1153.32 Watts (27.46 Amps @42V)
Total Power Available for Line Card Usage: 1153.32 Watts (27.46 Amps @42V)
Total Power Drawn From the System: 912.66 Watts (21.73 Amps @42V)
Remaining Power in the System: 240.66 Watts ( 5.73 Amps @42V)
Configured Default Inline Power allocation per port: 10.00 Watts (0.23 Amps @42V)
Slot power Requirement/Usage :
Slot Card Type PowerRequested PowerAllocated CardStatus
Watts A @42V Watts A @42V
1 WS-X6K-SUP1A-2GE 105.00 2.50 105.00 2.50 ok
2 WS-X6K-SUP1A-2GE 105.00 2.50 105.00 2.50 standby
3 WS-X6348-RJ-45 100.38 2.39 100.38 2.39 ok
4 WS-X6348-RJ-45 100.38 2.39 100.38 2.39 ok
5 WS-X6348-RJ-45 100.38 2.39 100.38 2.39 ok
6 WS-X6348-RJ-45 100.38 2.39 100.38 2.39 ok
7 WS-X6348-RJ-45 100.38 2.39 100.38 2.39 ok
8 WS-X6348-RJ-45 100.38 2.39 100.38 2.39 ok
9 WS-X6348-RJ-45 100.38 2.39 100.38 2.39 ok
Slot Inline Power Requirement/Usage :
Slot CardType Total Allocated Max H/W Supported Max H/W Supported
To Module (Watts) Per Module (Watts) Per Port (Watts)
01-03-2006 01:07 AM
perhaps you can try with show inventory, I don't know if it works with CatOS version.
Regards.
01-04-2006 03:01 PM
It depends on the version of code.
Visually it will state FAN TRAY 2 on the outside of the fan tray.
In later releases of CatOs show environment cooling is available:
Chassis per slot cooling capacity : 49 cfm
Fan tray(s) cooling capacity :
Fan Model Ver Cooling Ambient FanStatus
capacity temp
1 WS-C6513-CL 1 641 cfm - ok
Slot cooling requirement :
Slot CardType Cooling
01-04-2006 03:28 PM
01-05-2006 08:17 AM
NO LOVE?
