How to enable layer 3 routing on switch
dan_track
I have a 371098-001 switch with IOS 12.2(25)SED. I've been told its a layer 3 switch, however I don't know how to enable it to do routing, could someone please help me with this?
Dan
16 Replies 16
devang_etcom
Level 7
Level 7
hi dan,
yes you can have routing on switch...you can convert the perticular port in to the layer 3 using command no switchport under the perticular interface. and you can also configure the routing protocol and to eable routing i think you have to go for ip routing command
regards
Devang
ankurbhasin
Level 9
Level 9
Hi Dan,
As it is a layer 3 switch you will be able to configure routing and routing between the vlans which is intervlan routing.
To configure intervlan routing you have to configure logical interface for vlans after creating the vlans in vlan database and then assign them an ip address.
To configure layer 2 ports as layer 3 you have to give a command "no switchport" at interface config mode and assign an ip address and no shut.
To configure routing protocol you have to configure it the way you do on normal routers.
BUT very imp is that by default "ip routing" is disable you have to enable it first for any routing to work.
Make sure you enable "ip routing" command on global config mode.
Have a look at this link which will guide you how you can do normal routing and also to configure routing protocols on 3750 switch on the IOS code you are having on your switch
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225sed/scg/swiprout.htm
HTH, if yes please rate the post.
Ankur
Hi Ankur,
Thanks for the reply. The problem is that I don't have teh command "ip routing" on the switch, so I can't enable or disable it?
Any ideas what impact this has on enabling layer 3 functionality?
Dan
Just to add I do have the comand "ip host-routing", does this help in any way?
Dan
i think it will work lets try it out...
regards
Devang
Hi Dan,
If it is 3750 switch it will 100% be having "ip routing" command and without enabling this command routing functionality will not work.
try this
switch(config)#ip routing
ip host-routing is to configure your communication server to act as a terminal server and this will not enable layer 3 functionality on your switch.
Can you past the "sh version", "sh run" and output of ip ? from global config mode from your switch?
Ankur
Firstly thanks everyone for your replies.
result:
bl-sw-38(config)#ip routing
% Invalid input detected at '^' marker.
I've attached teh outputs of "sh version" and "sh run"
ip ? :
bl-sw-38(config)#ip ?
Global IP configuration subcommands:
access-list Named access-list
accounting-list Select hosts for which IP accounting information is
kept
accounting-threshold Sets the maximum number of accounting entries
accounting-transits Sets the maximum number of transit entries
address-pool Specify default IP address pooling mechanism
alias Alias an IP address to a TCP port
default-gateway Specify default gateway (if not routing IP)
dhcp Configure DHCP server and relay parameters
dhcp-client Configure parameters for DHCP client operation
dhcp-server Specify address of DHCP server to use
domain IP DNS Resolver
domain-list Domain name to complete unqualified host names.
domain-lookup Enable IP Domain Name System hostname translation
domain-name Define the default domain name
finger finger server
ftp FTP configuration commands
gdp Router discovery mechanism
gratuitous-arps Generate gratuitous ARPs for PPP/SLIP peer addresses
host Add an entry to the ip hostname table
host-routing Enable host-based routing (proxy ARP and redirect)
hp-host Enable the HP proxy probe service
http HTTP server configuration
icmp ICMP options
igmp IGMP global configuration
local Specify local options
name-server Specify address of name server to use
radius RADIUS configuration commands
rcmd Rcmd commands
reflexive-list Reflexive access list
security Specify system wide security information
source IP source
source-route Process packets with source routing header options
sticky-arp Allow the creation of sticky ARP entries
subnet-zero Allow 'subnet zero' subnets
tacacs TACACS configuration commands
tcp Global TCP parameters
telnet Specify telnet options
tftp tftp configuration commands
Hope this helps
Dan
Hi Dan,
It is not a 3750 switch but it is Cisco Gigabit Ethernet Switching Module something related to HP not very sure about this.
http://www.cisco.com/application/pdf/en/us/guest/products/ps6238/c1178/ccmigration_09186a00805e9dfe.pdf
Ankur
Dan this will help you
Configuring routing consists of several main procedures:
To support VLAN interfaces, create and configure VLANs on the switch stack, and assign VLAN membership to Layer 2 interfaces.
Configure Layer 3 interfaces.
Enable IP routing on the switch.
Assign IP addresses to the Layer 3 interfaces.
Enable selected routing protocols on the switch.
Configure routing protocol parameters
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00802c109a.html
rate this post if it helps
regards
Devang
If it's not a 3750, and it can't do routing, then why what would be the benefit of asking to set ip addressess for each interface?
Dan
dan
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_tech_notes_list.html
in this link posted by ankur ...in this document HP have give some information and also some IOS issue so you can try with your hp support also to resolve this issue
regards
Devang
dan do one thing
type just ip ?
what option is there i think you will find routing in it...
regards
Devang
amit-singh
Level 8
Level 8
Hi Dan,
This is a Cisco's Gigabit Ethernet switch module for HP blade servers. it is a pure layer 2 switch. Its not a layer 3 switch, so you cannot configure Layer 3 routing on it.
http://www.cisco.com/univercd/cc/td/doc/product/lan/bladesw/oemsw/cgesm/12225sed/cgesmscg.pdf
HTH, Please rate if it does.
-amit singh
so as per his post it is asking for the ip address...so is it for the management or what...
reards
Devang
