09-18-2003 10:16 AM - edited 03-02-2019 10:26 AM
Below is a show int
What is exactly TX and RX load? Looks like it is very high on the interface.
Looks like the drops are high too.
The 5 min output rate is very high too. Does the 5 minute mean avg. output rate for the 5 minutes or was it the peak output rate for 5 minutes.
Serial3/1:1 is up, line protocol is up
Hardware is Multichannel T1
Internet address is XX.xx.xx.xx
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
reliability 255/255, txload 213/255, rxload 96/255
Encapsulation PPP, crc 16, Data non-inverted
Keepalive set (10 sec)
LCP Open
Listen: CDPCP
Open: IPCP
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 7w0d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 24955299
Queueing strategy: weighted fair
Output queue: 0/1000/64/24955258 (size/max total/threshold/drops)
Conversations 0/17/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
5 minute input rate 584000 bits/sec, 285 packets/sec
5 minute output rate 1287000 bits/sec, 1109 packets/sec
1382477829 packets input, 1021681375 bytes, 0 no buffer
Received 0 broadcasts, 11 runts, 0 giants, 0 throttles
38 input errors, 16 CRC, 0 frame, 0 overrun, 0 ignored, 5 abort
1597696251 packets output, 485512542 bytes, 0 underruns
5 carrier transitions
no alarm present
Timeslot(s) Used:1-24, subrate: 64Kb/s, transmit delay is 0 flags
09-18-2003 11:07 AM
TXload and RXload are ratios of usage based on what the bandwidth is set to on the interface. It looks like you have a full T1 1.544Mbps. Your load does look high.
213/255=83% XMT
96/255=37% RCV
Looks like it's pretty full to me.
That's quite a bit; however, you don't know what timeframe that occured in since the interface counters were last cleared 7 weeks ago:
clear the interface counters and watch it over some time to see if the drops still are occuring.
If you still have high txload and rxload and are seeing drops steadily increment, you're out of bandwidth.
The 5 minute input rate and output rate is based on an average during the sampling period. To get more accurate results, decrease the load interval to 30 seconds by using the interface command:
load-interval 30
09-18-2003 11:13 AM
Thanks for the info!
