ISDN BRI Interface Bandwidth
rod.sizemore
What is the recommended bandwidth value for an ISDN BRI interface? Should it be left at the default of "64" for the purposes of the "dialer load-threshold" command calculations or should it be adjusted to "128" to reflect the two "B" channels that are available?
makchitale
Level 6
Level 6
The bandwidth command is used for routing decisions....changing the bandwidth on the BRI (the D channel) will not change the BW under the B1 & B2 channels which defaults to 64k....the dialer load threshold is based off the load on these bearer channels (B1, B2).
conf t
int bri x
bandwidth xxx
sh int brix / sh int brix 1 2
Thanks, Mak.
