isdn connection using ZyXEL TA
fusahinkaya
We want to make a isdn connection with a cisco 2500 router using ISDN TA ZyXel Omni TA128.
Bu I couldn't success to do it.
I have configured serial port as below:
Is anubody know the config that what is needed in ZyXEL side and alos router side?
interface Serial0
ip unnumbered Loopback0
no ip directed-broadcast
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer map ip 1.1.1.1 name aBaskent1 0703124057015
pulse-time 1
ppp authentication chap
ppp chap password xxxx
there is v35 cable between serial port and Zyxel.
Thanks in advance
Funda
I think the V.35 cable is not the right one, you need a DB-25 RS-232 cable for this to work.
GP
my first trial with rs232 but doesn't help also.
Incco I saw that the connection can be v35 or
if the ta support only rs232 v35 to rs232 converter.
Now ý tried second one.
thanks.
nihanth
hi
you want to make isdn connection between router and pc ( Isdn Ta is connected to )
1. We cann't connect isdn line to Serial 0 or 1 interface.
2 Isdn line should be connected to Bri or T1/E1 pri interfaces.
Router(Congif)#interface BRI0
Router(Congif-if)# ip unnumbered Ethernet0
Router(Congif-if)# no ip directed-broadcast
Router(Congif-if)# encapsulation ppp
Router(Congif-if)# dialer-group 1
Router(Congif-if)# isdn switch-type basic-net3
Router(Congif-if)# peer default ip address pool zoom
Router(Congif-if)# ppp authentication chap
Router(Congif)# ip local pool zoom 192.168.3.100 192.168.3.110
Router(Congif)# dialer-list 1 protocol ip permit
you should have 2503 router , Isdn line.
Pc side
1. install TA drivers
2. configure dialup adapter
i think your problem might be solved.
