ISDN PPP Dial out to Analog Modems
admin_2
Level 3
Level 3
Is it possible to use an ISDN BRI interface to call an asynchronous V.90 modem? I would like to set up an IP based dialer map on the ISDN interface to call remote sites with V.90 modems that support PPP. Any examples or sugesstions would be appreciated. Thanks.
tepatel
You need to have modem connected with a modem..So in the router with isdn line, if you have digital modem, then you can use that digital modem to callout over isdn line to connect to analog modem..So the requirement is to have a digital modem in the router..We have a product called 3600 router, which supports modem dialout/dialin over bri lines..Hre is the url for more info.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t3/3600mbri.htm
