Looking a replacement for Cisco Switch C4006
roopesh.n
Hi All,
Right Now we are using Cisco switch model c4006.and we are looking to replacement for the same . Below are our requirements.
1: Around 120 Ports (100 Mbps)
2: Around 30 Ports   (1Giga)
3: Layer2/Layer3
Can anyone suggest Which is the best model for my requerment .
Roopesh
The "logical" replacement would be a Catalyst 4500:
http://www.cisco.com/en/US/products/hw/switches/ps4324/index.html
But with that small amount of ports, a stack of four 3750X-48 would also work and gives you Gigabit on all ports for some bucks less:  http://www.cisco.com/en/US/products/ps10745/index.html
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Did u think about a 3750x stack? It depends on the requirement but I made good experience with that series and more than 120 ports copper.
