looking for OIDs for 2960s Temperature and Fan
Willem de Groot
Hi all
I'm looking for the OIDs for FAN, Temperature and Powerstate of each 2960s Switch in a Stack.
I can do a
show env switch 2
But were ist the OID für these "counters"
Willem
Ganesh Hariharan
Hi all
I can do a
show env switch 2
Willem
Hi Willem,
Try with these below option
CISCO-STACK-MIB::chassisTempAlarm.0 = INTEGER: off(1)
CISCO-ENVMON-MIB::ciscoEnvMonTemperatureState.1005 = INTEGER: normal(1)
Hope to Help !!
Ganesh.H
Ganesh Hariharan
Hi all
I can do a
show env switch 2
Willem
Hi Willem,
Hope to Help !!
Ganesh.H
Hi Ganesh.H
Thanks, this is what I was Looking for
Temp:
IOD: 1.3.6.1.4.1.9.9.13.1.3.1.3.1008 for the first Switch, 2008 for the second ...
Return. Value Celcius
FAN:
IOD:  1.3.6.1.4.1.9.9.13.1.4.1.3.1007  for the first Switch, 2007 for the second ....
return: 1= Normal
Powersupply:
OID: 1.3.6.1.4.1.9.9.13.1.5.1.3.1006   for the first Switch,1007 for the second .....
return 1 = Normal
Willem
Hi Ganesh.H
Temp:
FAN:
return: 1= Normal
Powersupply:
return 1 = Normal
Willem
Hi Willem,
That Great post has helped out ..it will be helpful if you can mark this thread has answered so that others get benifitted !!
Ganesh.H
