POE device from tird part is not recognized on 4507+E
edv
I have a UBIQUITI UAP-AC-PRO needing 802.3af POE/802.3at POE+.  I have connect it on a 4507 with WS-X4648-RJ45V+E card.  The description says: "WS-X4648-RJ45V+E Cisco Catalyst 4500E Series 48-Port 802.3af PoE and 802.3at PoEP 10/100/1000 (RJ-45)".  So this device should be compatible, but it was not detected by the switch.
I have tried with POE=auto and static but no result.  With an external power injector it works, so the AP is in order, i have changed the port and cables but same result.
Has somebody had same problems with third part devices with POE?
Any idea what i can do?
Thanks for your help!
Raphael
Leo Laohoo
Could potentially be a faulty cable.
Thanks for your answer Leo.  I have rechanged a second time the cable but same result!
Some other idea ?
Run a TDR test on the cable.
