PoE maximum output
Shams Rishad
What's the maximum power (Watt) that can be drawn from a single PoE port and a PoE+ port?
From my studies what I understand is around 15W for PoE (usable 12W) and 30W for PoE+ (usable 25.5W).
And for devices with power rating greater than this, PoE injectors are required.
Please share your knowledge.
TIA
Rishad
2 Accepted Solutions
Leo Laohoo
15.4w for PoE, 30.0w for PoE+ and 60.0w uPoE.
Mark Malone
so poe capabilities depend on the hardware in place , it can vary switch to switch and diff types of blades etc but usually the max is around 30 wqtt per port , but as below if your using 30w then you may only have a certain allowed amount per switch as there is a total poe watt count you cant go over , if you have devices that say only use 7 watt you can also set it to use less power per port
if you want to know what your device is capable of you would check the public data sheets , as an example here is one for te 2960x models
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/data_sheet_c78-728232.html
Most pf them are close enough
Table 8.       2960-X PoE and PoE+ Power Capacity
Switch Model
Maximum Number of PoE+ (IEEE 802.3at) Ports*
Maximum Number of PoE (IEEE 802.3af) Ports*
Available PoE Power (Single PS Source)
Cisco Catalyst 2960X-48FPD-L
24 ports up to 30W
48 ports up to 15.4W
740W
Cisco Catalyst 2960X-48LPD-L
12 ports up to 30W
24 ports up to 15.4W
370W
Cisco Catalyst 2960X-24PD-L
12 ports up to 30W
370W
Cisco Catalyst 2960X-48FPS-L
24 ports up to 30W
740W
Cisco Catalyst 2960X-48LPS-L
12 ports up to 30W
370W
Cisco Catalyst 2960X-24PS-L
12 ports up to 30W
370W
Cisco Catalyst 2960X-24PSQ-L
3 ports up to 30W
7 ports up to 15.4W
110W
Cisco Catalyst 2960XR-48FPD-I
24 ports up to 30W
740W
Cisco Catalyst 2960XR-48LPD-I
12 ports up to 30W
370W
Cisco Catalyst 2960XR-24PD-I
12 ports up to 30W
370W
Cisco Catalyst 2960XR-48FPS-I
24 ports up to 30W
740W
6 Replies 6
Leo Laohoo
Thanks a lot. I didn't know about uPoE. Just found out that this is Cisco proprietary and can deliver upto 60W through a port. Also discovered that my Cisco Unmanaged 110  Series switch doesn't support uPoE. My understanding is only 3 series support it.
Thanks. I've learnt a lot.
Mark Malone
Switch Model
24 ports up to 30W
740W
12 ports up to 30W
370W
12 ports up to 30W
370W
24 ports up to 30W
740W
12 ports up to 30W
370W
12 ports up to 30W
370W
3 ports up to 30W
7 ports up to 15.4W
110W
24 ports up to 30W
740W
12 ports up to 30W
370W
12 ports up to 30W
370W
24 ports up to 30W
740W
THat is a very helpful post. What about the WS-C2960X-48TS-L does that support power over ethernet?
I am not sure if  supports it or not , cause there is no command power inline auto under interface command
(config)#interface gi1/0/45
(config-if)#power inline auto
% Invalid input detected at '^' marker.
But still there are phones connected to it and I assume they getting power from the switch.
I have some phone issues like going offline and need to be sure if that is a power issue or not
Thank you,
Mery
Leo Laohoo
Thank you very much for taking the time to rate our posts.  :)
EdmundChee
Now, according to the latest syllabus of CompTIA A+ 220-1101 (year 2022), the information below are word-for-word:
Power over Ethernet (PoE) 802.3af allows powered devices to draw up to about 13W supplied as 350mA@48V, limited to 15.4 W, so the voltage drops over the maximum 100 feet of cable, resulting in usable power of only around 13W.
Power over Ethernet (PoE) 802.3at (PoE+) allows powered devices to draw up to about 25W, with a maximum current of 600 mA.
Power over Ethernet (PoE) 802.3bt (PoE++ or 4PPoE) supplies up to about 51W (Type 3) or 73W (Type 4) usable power.
