Problem with Cisco 831 router NAT translation or routing
ggutstadt
I’ve reviewed several post on this forum, very useful, and I think this 831 router config should allow for NAT'ng port 8080 to the ‘inside’ ip address, per this statement below. but my efforts have not been successful, no responses get back to outside client (xx.24.40).   clients on inside can communicate outbound fine. The iis server at .10.3 is definitely up and running on port 8080. I know this is probably a duplicate of other posts but if anyone can pinpoint my error I would really appreciate it!!
ip nat inside source static tcp 10.10.10.3 8080 interface Ethernet1 8080
Here is some debug ip nat output when attemping to connect on port 8080, do not get response back from server to external client (xx.24.40)….
Feb 03 13:22:49 10.10.10.1 297472: *Mar 2 00:09:31.894: NAT: o: tcp (xx.xx.254.40, 44123) -> (xx.xx.254.128, 8080) [21674]
Feb 03 13:22:49 10.10.10.1 297473: *Mar 2 00:09:31.894: NAT: s=xx.xx.254.40, d=xx.xx.254.128->10.10.10.3 [21674]
Feb 03 13:22:52 10.10.10.1 297474: *Mar 2 00:09:34.906: NAT: o: tcp (xx.xx.254.40, 44122) -> (xx.xx.254.128, 8080) [21678]
Feb 03 13:22:52 10.10.10.1 297475: *Mar 2 00:09:34.906: NAT: s=xx.xx.254.40, d=xx.xx.254.128->10.10.10.3 [21678]
Feb 03 13:22:52 10.10.10.1 297476: *Mar 2 00:09:34.906: NAT: o: tcp (xx.xx.254.40, 44123) -> (xx.xx.254.128, 8080) [21679]
Feb 03 13:22:52 10.10.10.1 297477: *Mar 2 00:09:34.906: NAT: s=xx.xx.254.40, d=xx.xx.254.128->10.10.10.3 [21679]
Feb 03 13:22:58 10.10.10.1 297478: *Mar 2 00:09:40.906: NAT: o: tcp (xx.xx.254.40, 44122) -> (xx.xx.254.128, 8080) [21684]
Feb 03 13:22:58 10.10.10.1 297479: *Mar 2 00:09:40.906: NAT: s=xx.xx.254.40, d=xx.xx.254.128->10.10.10.3 [21684]
Feb 03 13:22:58 10.10.10.1 297480: *Mar 2 00:09:40.906: NAT: o: tcp (xx.xx.254.40, 44123) -> (xx.xx.254.128, 8080) [21685]
Feb 03 13:22:58 10.10.10.1 297481: *Mar 2 00:09:40.910: NAT: s=xx.xx.254.40, d=xx.xx.254.128->10.10.10.3 [21685]
Feb 03 13:23:10 10.10.10.1 297482: *Mar 2 00:09:52.922: NAT: o: tcp (xx.xx.254.40, 44124) -> (xx.xx.254.128, 8080) [21698]
Feb 03 13:23:10 10.10.10.1 297483: *Mar 2 00:09:52.922: NAT: s=xx.xx.254.40, d=xx.xx.254.128->10.10.10.3 [21698]
Feb 03 13:23:13 10.10.10.1 297484: *Mar 2 00:09:55.930: NAT: o: tcp (xx.xx.254.40, 44124) -> (xx.xx.254.128, 8080) [21702]
Feb 03 13:23:13 10.10.10.1 297485: *Mar 2 00:09:55.930: NAT: s=xx.xx.254.40, d=xx.xx.254.128->10.10.10.3 [21702]
Feb 03 13:23:19 10.10.10.1 297486: *Mar 2 00:10:01.934: NAT: o: tcp (xx.xx.254.40, 44124) -> (xx.xx.254.128, 8080) [21709]
Feb 03 13:23:19 10.10.10.1 297487: *Mar 2 00:10:01.934: NAT: s=xx.xx.254.40, d=xx.xx.254.128->10.10.10.3 [21709]
Feb 03 13:23:58 10.10.10.1 297489: *Mar 2 00:10:41.306: NAT: expiring xx.xx.254.128 (10.10.10.3) tcp 8080 (8080)
538-R1023-C830#sh running-config full
Building configuration...
Current configuration : 4329 bytes
version 12.3
no service pad
hostname 538-R1023-C830
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
no aaa new-model
resource policy
ip subnet-zero
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 10.1.18.152
   lease 0 2
ip cef
ip domain list sd.cox.net
ip domain name sd.cox.net
no ip ips deny-action ips-interface
no ftp-server write-enable
crypto pki trustpoint TP-self-signed-75609932
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-75609932
revocation-check none
rsakeypair TP-self-signed-75609932
crypto pki certificate chain TP-self-signed-75609932
certificate self-signed 01
<snip>
interface Ethernet0
description inside
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Ethernet1
description outside
ip address dhcp
ip access-group 101 in
ip nat outside
duplex auto
interface Ethernet2
no ip address
shutdown
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
no ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface Ethernet1 overload
logging trap debugging
logging 10.10.10.3
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 101 permit ip any any
control-plane
banner login ^C
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
cadet alain
Is the client on the same subnet as the public IP of the router?
Have you verified the firewall on IIS machine?
Regards.
Alain
cadet alain
Regards.
Alain
Hi Alain,
yes, the client i was testing with is on the same subnet as public router ip.  Good thought on the firewall, I will disable any firewall on iis machine (my laptop) and re-test.  will reply with those results on Monday.   ultimately i'm needing to test nat for port 9100 to a printer, I'll add that and test as well, firewall shouldn't be a factor with printer.
thank you.
Grant
Yup, that was it.  DUH!  thanks for the assist Alain.  -grant
