Showing results forĀ
Search instead forĀ
Did you mean:Ā
problems doing NAT to a DCLINK server TCP port 3003
We use scanners talking to a DCLINK server on port 3003, when setting up NAT to the backup server  it will not connect to port 3003, though we can ping it and telnet on port 23 see relevent config below:
interface GigabitEthernet0/0.17
description DR Voice Vlan
encapsulation dot1Q 17
ip address 172.16.17.253 255.255.255.0
ip wccp 61 redirect in
ip nat outside
interface GigabitEthernet0/0.176
description DR data vlan
encapsulation dot1Q 176
ip address 172.17.6.252 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
interface FastEthernet0/3/0
description N3008351R IPMAN
bandwidth 10000
ip address 172.28.6.254 255.255.255.252
ip wccp 62 redirect in
ip flow ingress
ip flow egress
ip nat outside
ip nat inside source static 172.17.6.174 172.16.17.230
sh ip nat trans
Pro      Inside global                Inside local               Outside local                Outside global
udp 172.16.17.230:161       172.17.6.174:161   172.17.7.206:1647  172.17.7.206:1647
icmp 172.16.17.230:3528   172.17.6.174:3528 172.17.7.206:3528  172.17.7.206:3528
---            172.16.17.230      172.17.6.174                                ---                                          ---
anybody any ideas I have not had problems before with NAT, the server has not got any firewall setup
raga.fusionet
Level 4
Level 4
hi,
If you can ping and telnet and you have a one to one translation, I highly doubt it is an issue with the NAT configuration.
I would start looking at the server itself.
Raga
