QOS problem (multicast) with 3750
etxnreg
I need help to solve following problem.
I have setup qos in our 3750, see below.
Unicast traffic is handle correct, However with multicast streams the router set the dscp to 0
Has somebody any idea what is missing?
Too old sw?   Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(35)SE,
Regards Niklas
ip multicast-routing distributed
ip multicast multipath
mls qos srr-queue input priority-queue 1 bandwidth 10
mls qos srr-queue input dscp-map queue 1 threshold 1  46
mls qos srr-queue input dscp-map queue 2 threshold 1  11 24 30 48
mls qos srr-queue output dscp-map queue 1 threshold 1  48
mls qos srr-queue output dscp-map queue 2 threshold 1  46
mls qos srr-queue output dscp-map queue 3 threshold 1  40
mls qos srr-queue output dscp-map queue 4 threshold 1  11 24 30
mls qos
interface GigabitEthernet1/0/22
switchport access vlan 41
switchport mode access
load-interval 30
srr-queue bandwidth share 25 25 25 20
priority-queue out
mls qos trust dscp
interface GigabitEthernet1/0/23
switchport trunk allowed vlan 40
switchport mode trunk
load-interval 30
priority-queue out
mls qos trust dscp
You welcome.
To see which queue is dropping use "show plat port-asic stats drop x/x"
HTH,
Lei Tian
12 Replies 12
Lei Tian
Hi Niklas,
You are trusting DSCP on the interface; if the receiving traffic with dscp 0, the switch will not change it unless you configure the switch to do it.
HTH,
Lei Tian
The multicast stream has dscp 32 , when is leaving 3750 it has 0.
With unicast traffic this behavior is not occur.
BR Niklas
Hi Niklas,
Did you check the statistics from that 2 interfaces? Can you post the output?
show mls qos interface x/x statistics
thanks,
Lei Tian
Here comes the printouts:
with mls qos enabled:
cisco-Mcast#sh mls qos interface gigabitEthernet 1/0/22 statistics
  dscp: incoming
  0 -  4 :           0            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :     8881981            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0          307            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :           0            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  5 -  7 :           0          307            0
Policer: Inprofile:            0 OutofProfile:            0
cisco-Mcast#sh mls qos interface gigabitEthernet 1/0/23 statistics
  dscp: incoming
  0 -  4 :     8931330            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0          202            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :           0            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0         1206            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :    11357772            0            0            0            0
  5 -  7 :           0            2            0
  cos: outgoing
  0 -  4 :           0            0            0            0            0
  5 -  7 :           0         1206            2
cisco-Mcast#
mls qos disabled:
  dscp: incoming
  0 -  4 :           0            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :           0            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0         7371            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :           0            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :        7371            0            0            0            0
  5 -  7 :           0            0            0
  dscp: incoming
  0 -  4 :           0            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0        23281            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :           0            0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0            0            0            2            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :       29272            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :           0            0            0            0            0
  5 -  7 :           0            2            0
cisco-Mcast#
BR Niklas
So the problem is after you turn on mls qos, switch rewrite dscp to 0 for all multicast traffic, and all unicast traffic are fine.  Will it make difference if you change g1/0/23 to access port?
What is the code version that switch running?
Yes that's correct.
Very strange behavior.
BR Niklas
Yes, that is abnormal. Is that switch a L3 or L2 switch? where are the L3 interfaces terminate?
The switch is a layer3
interface Vlan40
ip address 10.0.0.1 255.255.255.0
ip pim sparse-mode
interface Vlan41
ip address 192.168.98.129 255.255.255.128
ip pim sparse-mode
Have also upgraded the switch to the latest software.
No changes
Any ideas?
BR Niklas
So since you changed the code and still seeing the same, I think probably that't not a software issue.
How does the multicast traffic flow from source to the receiver? Is that interface directly connected to the multicast source? Can you post the output of show ip mroute on the switch?
Lei Tian
The multicat source is not directly connected.
I really appreciate your help
BR Niklas
cisco-Mcast#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 233.12.166.131), 19:38:44/00:02:52, RP 192.168.90.1, flags: SP
  Incoming interface: Vlan40, RPF nbr 10.0.0.2
  Outgoing interface list: Null
(*, 233.12.166.48), 19:38:46/stopped, RP 192.168.90.1, flags: SJC
    Vlan41, Forward/Sparse, 19:38:45/00:02:21
(213.204.47.175, 233.12.166.48), 19:38:45/00:02:52, flags: JT
(*, 233.12.166.46), 19:38:44/stopped, RP 192.168.90.1, flags: SJC
    Vlan41, Forward/Sparse, 19:38:44/00:02:16
(213.204.47.175, 233.12.166.46), 19:38:44/00:02:52, flags: JT
(*, 233.12.166.47), 19:38:46/stopped, RP 192.168.90.1, flags: SJC
    Vlan41, Forward/Sparse, 19:38:45/00:02:16
(213.204.47.175, 233.12.166.47), 19:38:45/00:02:52, flags: JT
(*, 233.12.166.44), 19:38:46/stopped, RP 192.168.90.1, flags: SJC
(213.204.47.160, 233.12.166.44), 19:38:44/00:02:52, flags: JT
(*, 224.0.1.40), 19:39:21/00:02:18, RP 192.168.90.1, flags: SJCL
    Loopback0, Forward/Sparse, 19:39:19/00:02:18
cisco-Mcast#
Hi Again,
I have found the issue.
I had forgot to activate mls qos trust dscp on one interface.
Thanks gain for all help.
Question.
What is the command to see in which queue traffic is dropping?
BR Niklas
You welcome.
HTH,
Lei Tian
