router problem
wanhwai
System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVELOPMEN
T SOFTWARE
Copyright (c) 1994-2000 by cisco Systems, Inc.
C7200 platform with 65536 Kbytes of main memory
Self decompressing the image : #################################################
########################################################################### [OK]
%SYS-4-CONFIG_NEWER: Configuration from version 12.1 may not be correctly unders
tood
%SYS-6-READ_BOOTFILE_FAIL: disk0:c7200-is-mz.121-19.bin File boot failed -- File
not accessible.
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
boot of "cisco2-C7200" using boot helper "bootflash:c7200-boot-mz.120-13.S" fail
ed
error returned: File boot failed -- File not accessible
loadprog: error - on file open
boot: cannot load "cisco2-C7200"
T SOFTWARE
open(): Open Error = -9
boot: cannot load "slot0:c7200-is-mz.121-19.bin"
T SOFTWARE
loadprog: bad file magic number: 0x0
boot: cannot load "slot0:"
T SOFTWARE
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 7200 Software (C7200-BOOT-M), Version 12.0(13)S, EARLY DEPLOYMENT RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Fri 29-Sep-00 17:46 by pwade
Image text-base: 0x60008948, data-base: 0x606AA000
cisco 7204VXR (NPE225) processor with 57344K/8192K bytes of memory.
R527x CPU at 262Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
4 slot VXR midplane, Version 2.1
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
125K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
4096K bytes of Flash internal SIMM (Sector size 256K).
After that followed by
Router(boot)>
1.May i know what is the reason?
2.What should i do?
3.Actually this is the router for ATM ,after this my router's traffic cannot go out but can come in?
thisisshanky
Level 11
Level 11
Your router is not properly booting because it is not able to read from slot 0 (your PCMCIA slot). It is currently on RX boot mode (Router(boot)>) Either your flash/bootflash/pcmcia is not formatted properly or the file is corrupt
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
marikakis
Level 7
Level 7
Since you are lucky enough to be in boot mode,
you can try to copy a new (and correct) IOS into a properly formatted flash:
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a0080110ed1.shtml#intro
M.
suatteber
Check your IOS file and compare it's size with healty one. You have to copy an IOS file by using TFTPDNLD at first step anyway. Also make sure PCMCIA card fixed well.
Suat Teber
Istanbul
