08-19-2002 03:31 PM - edited 03-02-2019 12:46 AM
I have 8Mb onboard Flash SIMM on RSM module WS-X5302 installed in Cat5500 running IOS version 12.0(21a).
I want to upgrade the IOS version to 12.1(16) which requires 16MB onboard SIMM.
What is the Cisco part No for the 16MB onboard FLASH SIMM for WS-X5302??
Mohan Kulhalli
08-19-2002 03:37 PM
We do not have 16MB DRAM SIMMS. We have 32M, 64M and 128M and the part numbers are as follows
MEM-RSM-64M=
MEM-RSM-128M=
MEM-RSM-32M=
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/cnfg_nts/rsm/78_4592.htm#xtocid188980
Not sure if we have bootflash upgrade SIMMs. We have the following flash cards
PCMCIA Cards:
MEM-RSM-FLC16M=
MEM-RSM-FLC20M=
08-19-2002 03:42 PM
Those are DRAM SIMMS. Can they be used for Onboard Flash ( bootflash) to burn IOS in it ??
Thanks for quick reply.
Mohan Kulhalli
08-19-2002 04:01 PM
You are correct..Those are DRAMs and you cannot boot IOS from it. You can use the flash cards instead
MEM-RSM-FLC16M=
MEM-RSM-FLC20M=
I do not believe we have an upgrade for onboard flash but I'll research to see if there is an upgrade for it and let you know
08-19-2002 04:15 PM
I have already used the flash card for the upgarde. But found one of the articles on CCO mention a flash SIMM of 16MB for RSM and I did not find the part No. to order it .
The IOS version 12.1(16) is 9.2Mb which requires at least 16Mb - to burn in.
Please note there is just ONE slot for Flash SIMM on RSM and hence we need a 16MB Flash SIMM to replace it for the IOS upgrade.
Thanks for any feedback
Mohan Kulhalli
