Setting up a Span session for an Etherchannel
bbriggs
Does anyone know of a Cisco web page, I haven't found one, which explains how traffic on a CatOS switch is transferred from a 4 port etherchannel to a single span port. For example, I need to know how a single 100Mb\s Full duplex port handles traffic from four 100Mb\s Full duplex ports. I am querying this as I need to be able to estimate real-time data transfer rates over an etherchannel.
Cant tell if you are after span info or port statistics, so here's both.
When you span an etherchannel port to another port it will show you that it spanned all of the ports in the channel. If the aggregate of those ports is too much for the span port packets will be dropped. See below when I span 4/10 it responds that the source is 4/10,8/11.
CAT2> (enable) sh port chann
Port Status Channel Admin Ch
Mode Group Id
4/9 connected on 249 769
4/11 connected on 249 769
4/1 connected on 137 865
4/2 notconnect on 137 865
5/1 connected on 137 865
5/2 notconnect on 137 865
4/10 connected on 248 869
8/11 connected on 248 869
4/12 connected on 247 870
8/10 connected on 247 870
Port Device-ID Port-ID Platform
4/9
4/11
4/1 SCA04020134(CAT1) 4/16 WS-C6509
4/2
5/1 SCA04020134(CAT1) 6/16 WS-C6509
5/2
4/10
8/11
4/12
8/10
CAT2> (enable) set span 4/10 9/48
2003 Jul 28 08:12:52 CST -06:00 %SYS-5-SPAN_CFGSTATECHG:local span session inact
ive for destination port 9/48
Destination : Port 9/48
Admin Source : Port 4/10
Oper Source : Port 4/10,8/11
Direction : transmit/receive
Incoming Packets: disabled
Learning : enabled
Multicast : enabled
Filter : -
Status : active
These next commands show counters on the port.
CAT2> (enable) sh port count 9/48
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
9/48 6 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
9/48 70797 5635 2 13 0 6 0
Last-Time-Cleared
CAT2> (enable) sh port mac 9/48
Port Rcv-Unicast Rcv-Multicast Rcv-Broadcast
9/48 0 0 280797
Port Xmit-Unicast Xmit-Multicast Xmit-Broadcast
9/48 39602686381 150896080 56869577
Port Rcv-Octet Xmit-Octet
9/48 38871910 16512185621934
MAC Dely-Exced MTU-Exced In-Discard Out-Discard
9/48 0 0 20 1845957779
Prashanth Krishnappa
If the destination SPAN port is congested, packets are dropped in the output queue.
The 6500 in question is not IOS based i.e. the command set is the older " set vlan" type. I can use "show port" or "show port counters". This gives me statistics for collisions, runts, giants, alignment errors, FCS's,and also transmit & receive errors.
I know that switches which use the standard IOS arrangement which has interfaces as opposed to ports can yield statistics on output queues but how can I get these stats here?
Apologies if the switch type \ OS was unclear.
Mode Group Id
4/9
4/11
4/2
5/2
4/10
8/11
4/12
8/10
Learning : enabled
Multicast : enabled
Filter : -
Status : active
9/48 6 0 0 0 0
Last-Time-Cleared
9/48 0 0 280797
Thanks, the show port mac probably indicates the packets discarded through not being capable of being transmitted. This should give me an idea of how many packets are lost by trying to pass a potential 4 X 100Mb\s of data down a single 100 Mb\s port.
