Setting up trunk link between 3745 and 2950
sanjaynadarajah
I need some help to setup a trunk link between the 3745 and the 2950.
The problem is that I am not familiar with the 3745 router and when I enter interface configuration mode, it has only the command 'trunk-group' which it says it is only for ISDN. I am setting up a normal ethernet link.
What would the configuration be on the 3745 equipment ?
Thanks in advance,
-SN-
10 Replies 10
pkhatri
Level 11
Level 11
The way to setup the trunk link on a router interface is to create sub-interfaces corresponding to each VLAN. For example:
interface FastEthernet0/0
no ip address
interface FastEthernet0/0.100
ip address x.x.x.x y.y.y.y
encapsulation dot1q 100
interface FastEthernet0/0.200
encapsulation dot1q 200
Hope that helps - pls rate the post if it does.
Paresh
This is what I think the configuration should be on the 2950 switch.
conf t
interface fa0/33
switchport mode trunk
switchport trunk allowed vlan 101,102,104
end
This is connected to the other end to the 3745 router on ports fa1/0 whereby I have created the vlans 101,102 and 104.
[1] What I am stuck is where do I give it an IP on the 2950 for it to communicate to the 3745 router ?
The IPs on the 3745 subinterfaces are 30.201,30.209 and 30.217
172.21.30.201 - 172.21.30.206
172.21.30.209 - 172.21.30.214
172.21.30.217 - 172.21.30.222
[2] What else should I do to make this switch communicate to the 3745 router ?
[3] Also is there any documentation that I can look up for configuration references and samples.
Thank you,
- SN -
Hi Sanjay,
What you want is intervlan routing using an external router 3745 in your case.
Have a look at this link with topology and configuration
http://www.cisco.com/warp/customer/473/50.shtml#801.1Q
Also the subinterfaces ip address will be the gateway on workstation on respective vlans and to let 2950 cumminicate to your router you have to have an ip addres on 2950 on any of the vlans which you have created on subinterfaces but make sure on 2950 being a layer 2 switch you can have only one interface vlan active and can assign an ip address on it.
HTH, if yes please rate the post.
Ankur
Ankur,
Yes, I read the doc and understand it now. I will try this out soon.
Btw, how do you find these documentations rather fast from the cisco website ? I am not able to get the right documentation to solve my problems to date.
Thank you sir,
-SN-
Hi Sanjay,
Lot of documents are from my favorite list but you can visit
www.cisco.com/univercd
When you open this link you will there is a drop down menu for switches and when you get it open you will see lot of IOS release and then you can click on software confguration guide to check different cofigs and features.
Ankur
I manage to setup this 3745 and 2950 but here is the problem that I noticed :-
1) I can ping from the 3745 to the 2950 and a host on vlan101.
2) From the host, I cannot ping the gateway of the other vlan which is the subinterface on the 3745 nor can the traffic go out to the campus network.
3) Since it cannot ping the gateway of the other vlan, I am not too sure if routing is turned on the 3745. I have typed in 'ip routing' but when I do a
'show run' it does not seem to be there.
I have attached the config of the 3745 router and the 2950 switch. What do I need to do to allow the host on the 2950 to ping the other subinterfaces and go to the broader network.
Please advice,
-SN-
Hi Sanjay,
You will not see "ip routing" in sh run because it is by default enabled and any command which is by default enabled will not be displayed in sh run but yes if you disable it you will see it in sh run because that is not the default behavior.
Now coming to te problem this happens many a times when you cofigure intervlan routing an sometime IOS behave wierd. Because there is no reason why it should not ping the ip which are directly connected on the router.
But let us confirm if trunk is up or not cause most probably that could be the issue. Can you paste the output of "sh interface FastEthernet0/33 switchport" from the switch and also paste the output of "sh ip route" from the router.
Ankur
#sh interface FastEthernet0/33 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: 101,102,104
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
172.21.0.0/16 is variably subnetted, 5 subnets, 3 masks
C 172.21.30.192/30 is directly connected, GigabitEthernet3/0
C 172.21.30.200/29 is directly connected, FastEthernet1/0.101
C 172.21.30.208/29 is directly connected, FastEthernet1/0.102
C 172.21.30.216/29 is directly connected, FastEthernet1/0.104
S 172.21.0.0/16 [1/0] via 172.21.30.193
Ankur,
I am also using this static route 172.21.0.0/16 so that it can talk to the campus network. I am doing this instead of enabling eigrp. This is okay right ?
-SN-
Ankur,
I have enabled eigrp on the router and everything is working fine now. I am a bit confused now reason being is that I thaught that
1) static routes would be the same as a dynamic route in this instance. The static route that I used on the router that I was setting on was :-
ip route 172.21.0.0 255.255.0.0 172.21.30.193
which says that direct all trafic from 172.21.0.0/16 to the ip 172.21.30.193 which is the next hop ip of this router.
[1] Isn't the static route and enabling eigrp would mean the same thing here ?
[2] Do I need a default gateway for this router ?
Problem solved but I need to really understand what is going on here.
Thank you very much for you help so far Ankur.Appreciate it.
-SN-
