Trying to join a 1231G AP to 2504 Controller
Dave Aubert
Controller is running 7.6.130.0.  Experiencing errors below and the AP keeps rebooting after the failed join request.
Error on controller:
*spamApTask0: Jul 09 13:50:07.031: #CAPWAP-3-DECODE_ERR: capwap_ac_sm.c:4451 Error decoding Join request from AP 00:0f:8f:32:81:87
Errors on AP:
*Mar 30 10:19:32.676: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 30 10:19:42.682: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jul 9 18:37:58.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.9.2 peer_port: 5246
*Jul 9 18:37:58.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul 9 18:37:59.874: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.9.2 peer_port: 5246
*Jul 9 18:37:59.876: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.9.2
*Jul 9 18:37:59.877: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Jul 9 18:38:04.876: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.9.2
*Jul 9 18:38:04.884: %DTLS-5-ALERT: Received WARNING : Close notify alert from 172.16.9.2
*Jul 9 18:38:04.885: %DTLS-5-PEER_DISCONNECT: Peer 172.16.9.2 has closed connection.
*Jul 9 18:38:04.885: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 172.16.9.2:5246
*Jul 9 18:38:04.886: %CAPWAP-3-ERRORLOG: Go join a lwapp controller
*Jul 9 18:38:04.886: %LWAPP-3-CLIENTERRORLOG: Set Transport AddressCalled
*Jul 9 18:38:09.892: %LWAPP-3-CLIENTERRORLOG: Join Timer: did not recieve join response (controller - SKWLC)
*Jul 9 18:38:09.892: %LWAPP-3-CLIENTERRORLOG: Set Transport AddressCalled
*Jul 9 18:38:09.893: %LWAPP-3-CLIENTERRORLOG: Set Transport Address: no more AP manager IP addresses remain
*Jul 9 18:38:10.114: %SYS-4-PUPDATECLOCK: Periodic Clock update with ROMMON failed, because size left in ROMMON (4294967295), size needed (29), error code (-1)
*Jul 9 18:38:10.115: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET JOIN RESPONSE.
*Jul 9 18:38:10.116: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
Leo Laohoo
If you need to support AP1230 then you'll need to downgrade the firmware on the 2504 to 7.0.X.X.
Go HERE and scroll down to Table 2.
