03-09-2005 05:09 AM - edited 03-02-2019 10:04 PM
Hi my situation is freeradius give the switch wrong attribute parameters.
The users config file says:
Username Auth-Type == EAP, User-Password == xxx
Framed-Type = Framed,
Tunnel-Medium-Type:1 = 6,
Tunnel-Type:1 = 13,
Tunnel-Private-Group-ID:1 = 13
on freeradius debuging I can see:
Sending Acces-Accept of id 59 to xxx.xxx.xxx.xxx:1812
Tunnel-Medium-Type:1 = IEEE-802
Tunnel-Type:1 = VLAN
Tunnel-Private-Group-Id = 13
and thats the problem. I think the Tunnel-Private-Group-Id is not more an
Integer
The Switch Radius Debug
04:57:06: Attribute 65 6 01000006
04:57:06: Attribute 64 6 0100000D
04:57:06: Attribute 81 5 0131334F
Attribute 65 and 64 are ok but Attribute 81 is the problem
03-15-2005 09:15 AM
As for as I know , for reasons of administrative scalability, RADIUS profiles are usually configured at the group level rather than one for each user. To configure a VLAN ID to be assigned to all users belonging to a specific group accessing the network through a Cisco Catalyst 4000, 5000, or 6000 Switch, navigate to that group's page within Cisco Secure ACS and locate the IETF RADIUS settings section. If the steps above on Interface Configuration have been followed, then attributes Tunnel-Type [# 64] and Tunnel-Private-Group-ID [# 81] will appear there for configuration.
For more information :http://www.cisco.com/en/US/customer/products/sw/secursw/ps2086/products_white_paper09186a0080088890.shtml
03-15-2005 09:34 AM
Attribute 81 needs to be the VLAN name and not the number, plus you need the following on the switch (synamic VLANS only work with EMI image I think?):
aaa authorization network default group Radius-Servers
Andy
03-15-2005 12:05 PM
I have just been testing this on a 2950-EI (12.1(22)EA3) and a 3550 (12.2(25)SEA) and option 81 can be set to either the VLAN name or number.
Andy
