08-02-2004 04:41 AM - edited 03-02-2019 05:27 PM
We have a network with a single 6500 switch (with internal MSFC). Our buildings each have 3500's as their core. Our 6500 is performing the routing between each building and controls the VLAN's. We would like to be able to send WOL (wake on lan) packets across the WAN. How do we force the router to allow these broadcasts?
08-02-2004 09:09 AM
I think WOL uses UDP port 9. Try the global command:
ip forward-protocol udp 9
on your switch.
HTH,
Georg
08-02-2004 12:01 PM
Georg,
Thanks for your post. We need to make the change on the router portion of the msfc. Is that what you are referring to?
08-03-2004 12:14 AM
exactly, add that line, in global configuration mode, to the router portion of the MSFC.
Let me know if this works...I have not tested this myself...:)
GP
