3015 stops IP traffic on ethernet using webvpn
vosm
I have an unusual situation, we use webvpn and one specific site doing a specific task makes our concentrator stop talking via ip out any of it's ethernet ports. You can console in and it shows nothing, everything says up, no crash log, it doesn't realize it isn't talking above layer 2, the layer 2 appears fine but nothing else out the ethernet ports. We are version 4.1(7)d on the concentrator, I have a tac case open but nobody can figure out why the concentrator would do this.
Our users are using Tortuis CVS and this seems to be the only software causing this, unfortunately and obviously we need to use this.
Any ideas, debugging options, insight would be appreciated.
umedryk
Level 5
Level 5
If you are using PIX some where in between, please make sure you have proper conduit permit statements.
