10-19-2004 03:47 PM - edited 03-09-2019 09:09 AM
Does anyone know the exact model of a SCSI hard drive that comes with a 4235 and 4250?
Do these two sensors use the same harddrive type?
10-20-2004 07:51 AM
The IDS-4235 and IDS-4250 both use the same HDD. A spare can be ordered using Cisco P/N IDS-SCSI=.
-Rusty
10-20-2004 07:52 AM
The harddrive is available for purchase from Cisco using the following part number:
IDS-SCSI=
The description states for the 4250, but it will also work in the 4235 (they do use the same harddrives).
10-21-2004 07:32 AM
What is the disk capacity and speed?
