About Idle timeout
engel
Level 2
Level 2
Dear all,
The command "timeout" is for configuring "idle" timeout until the slot is freed.
From the manual, UDP idle timeout is configureable, from the default of 2 minutes. I have the following questions:
1. Does TCP connection idle time-out is configureable or not ?
2. Does it possible to configure UDP or TCP idle timeout base on port number ? For example, TCP port 23 idle timeout is 1 minutes, TCP port 110 idle is 30 seconds, etc.
Appreciate for any help.
Best Regards,
Engel
steve.barlow
Level 7
Level 7
1.
For IOS:
ip nat translation udp-timeout
ip nat translation dns-timeout
ip nat translation tcp-timeout
ip nat translation finrst-timeout
ip nat translation syn-timeout
ip nat translation icmp-timeout
For PIX:
timeout [xlate [hh:mm:ss]] [conn [hh:mm:ss]] [half-closed [hh:mm:ss]] [udp [hh:mm:ss]] [rpc [hh:mm:ss]] [h323 [hh:mm:ss]] [uauth [hh:mm:ss] [absolute | inactivity]]
2. No, don't think so.
Steve
jclemmons
No you cannot configure TCP timeout by port number but TCP timeout value is configurable.
TIMEOUT CONN hh:mm:ss (minimum 5 minutes).
I believe default is one hour.
We've been asking the question as well due to an application problem using Microsoft SNA gateways on inside and client remote desktops on outside segment.
