ACL outside interface permit DHCP
ranbeckycr
Hello Experts,
Easy question
router fa0/0 (outside interface)- address obtained by DHCP from ISP
I need to know how I can create an acl in the outside int of the router that allows me to BLOCK all other traffic but to allow my router to continue accepting the ip address by DHCP.
Will this rule work?
ip access-l ext outside
permit tcp any int fa0/0 eq 68
permit udp any int fa0/0 eq 68
permit tcp any int fa0/0 eq 67
permit udp any int fa0/0 eq 67
int fa0/0
access-g outside in
Or should I configure something else?
Thanks for any advice.
Randall
Please help
ranbeckycr
I hope somebody can help me.
thx
mvsheik123
Level 7
Level 7
Only for DHCP it works ( I have not tested though), but you might need to open for DNS also.
hth
MS
