After SG350-10 factory reset, default password is not working.
Pusik
I logged in the SG350-10 switch with the default id and password (cisco/cisco) and changed new id and password.
It had worked well but It didn't work well after I updated the firmware.
My new id and password didn't work and the default ones didn't work too.
So, I tried to factory-reset the switch but the default id and password doesn't work well.
Both cisco/cisco and admin/admin are not working.
Now, I can't log in the switch.
Please help me.
Richard Burts
Are you attempting to log in using telnet/SH or using he console?
Rick
balaji.bandi
Is your password contains any special characters - I believe some users have same issue, you need to do factory reset to get access (you loose all the config if you do not have any backup)
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb4985-administrator-password-recovery-for-300-and-500-series-manag.html
BB
