architecture to connect a customer to a Lan through a concentrateur ???
bfarid
What architecture should we adopt to connect a customer VPN 3.5 to Lan via a concentrator, where should we install the concentrator?
Thank you
awaheed
Hi Farid,
I am not sure if I understood your question correctly, but I will try to answer what I thought of it, and then you can re-ask it if you have anything further.
You can go ahead and use the following to be able to connect from a client to the Concentrator: http://www.cisco.com/warp/public/471/ipsec_3000.html
Hope this helps,
Aamir
