06-07-2020 03:35 AM
Dear all,
I had an issue with Static NAT, the task is - RADIUS client must be masqueraded from real IP 192.168.53.240 to assigned 192.168.46.1
i'we made my config as it in ASA Book:
My config:
object network RADIUS host 192.168.46.250 object network RADIUS nat (G_STAFF_INSIDE,G_STAFF_OUTSIDE) static 192.168.46.1 access-list OUTSIDE extended permit udp any host 192.168.46.250 range 1812 1813 access-group OUTSIDE in interface G_STAFF_OUTSIDE
G_STAFF_OUTSIDE - ingress interface(network 192.168.53.0/24),
G_STAFF_INSIDE - egress interface(network 192.168.46.0/24)
packet-tracert:
ASA(config)# packet-tracer input G_STAFF_OUTSIDE udp 192.168.53.240 11111 192.168.53.235 1812
Phase: 1 Type: CAPTURE Subtype: Result: ALLOW Config: Additional Information: MAC Access list Phase: 2 Type: ACCESS-LIST Subtype: Result: ALLOW Config: Implicit Rule Additional Information: MAC Access list Phase: 3 Type: ROUTE-LOOKUP Subtype: Resolve Egress Interface Result: ALLOW Config: Additional Information: found next-hop 192.168.53.235 using egress ifc identity Phase: 4 Type: NAT Subtype: per-session Result: ALLOW Config: Additional Information: Phase: 5 Type: ACCESS-LIST Subtype: Result: DROP Config: Implicit Rule Additional Information: Result: input-interface: G_STAFF_OUTSIDE input-status: up input-line-status: up output-interface: NP Identity Ifc output-status: up output-line-status: up Action: drop
I will be really appreciate for any help or advice.
Alex
Solved! Go to Solution.
06-10-2020 11:11 PM
So, i found a solution:
subnet 192.168.53.0 255.255.255.0
nat (G_STAFF_OUTSIDE,G_STAFF_INSIDE) source dynamic RADIUS interface
access-list A_RUCKUS_INCOMMING extended permit udp any4 any4 range 1812 1813
access-group A_RUCKUS_INCOMMING in interface G_STAFF_OUTSIDE
as a destination for request you should put real IP address of server and as aGW will be OUTSIDE interface of ASA.
BTW, Many thanks to Sheraz.Salim for his kind help and efforts!
Sia,
Alex
06-07-2020 05:01 AM - edited 06-07-2020 05:06 AM
try this and past the result
host 192.168.46.250
nat (G_STAFF_INSIDE,G_STAFF_OUTSIDE) static 192.168.53.X
packet-tracer input G_STAFF_OUTSIDE udp 8.8.8.8 11111 192.168.53.X 1812
06-07-2020 10:27 PM
Dear Sheraz Salim,
Thanks for your quick reply, i tried your example with error:
ASA(config)# object network RADIUS ASA(config-network-object)# host 192.168.46.250 H9764-GST-ASA(config-network-object)# nat (G_STAFF_INSIDE,G_STAFF_OUTSIDE) static 192.168.53.235 ERROR: Address 192.168.53.235 overlaps with G_STAFF_OUTSIDE interface address. ERROR: NAT Policy is not downloaded
192.168.53.235 - IP of ingress interface
even if i apply 192.168.53.240 (device that initiate connection i get same output from packet tracer:
ASA(config)# packet-tracer input G_STAFF_OUTSIDE udp 192.168.53.240 11111 192.168.53.235 1812 Phase: 1 Type: CAPTURE Subtype: Result: ALLOW Config: Additional Information: MAC Access list Phase: 2 Type: ACCESS-LIST Subtype: Result: ALLOW Config: Implicit Rule Additional Information: MAC Access list Phase: 3 Type: ROUTE-LOOKUP Subtype: Resolve Egress Interface Result: ALLOW Config: Additional Information: found next-hop 192.168.53.235 using egress ifc identity Phase: 4 Type: NAT Subtype: per-session Result: ALLOW Config: Additional Information: Phase: 5 Type: ACCESS-LIST Subtype: Result: DROP Config: Implicit Rule Additional Information: Result: input-interface: G_STAFF_OUTSIDE input-status: up input-line-status: up output-interface: NP Identity Ifc output-status: up output-line-status: up Action: drop
Will be appreciate for your kind help,
Alex
06-08-2020 03:49 AM
you outside ASA interface ip address is 192.168.53.235
and your private Radius server is 192.168.46.250
and you also barrow a spare ip address from your outside interface let say 192.168.53.10
H9764-GST-ASA(config-network-object)# nat (G_STAFF_INSIDE,G_STAFF_OUTSIDE) static 192.168.53.10
access-list OUTSIDE_IN extended permit udp any host 192.168.46.250 eq 1812
access-group OUTSIDE_IN in interface outside
packet-tracer input G_STAFF_OUTSIDE udp 8.8.8.8 11111 192.168.53.235 1812
or
packet-tracer input G_STAFF_OUTSIDE udp 192.168.53.7 1812 192.168.53.235 1812 detail
06-08-2020 04:10 AM
Dear Sheraz Salim,
Nope, i tried:
ASA(config)# object network RADIUS ASA(config-network-object)# host 192.168.46.250 ASA(config-network-object)# nat (G_STAFF_INSIDE,G_STAFF_OUTSIDE) static 192.168.53.236 access-list OUTSIDE_IN extended permit udp any host 192.168.46.250 eq 1812 access-group OUTSIDE_IN in interface outside
and get same issue:
ASA# packet-tracer input G_STAFF_OUTSIDE udp 8.8.8.8 11111 192.168.53.235 1812 Phase: 1 Type: CAPTURE Subtype: Result: ALLOW Config: Additional Information: MAC Access list Phase: 2 Type: ACCESS-LIST Subtype: Result: ALLOW Config: Implicit Rule Additional Information: MAC Access list Phase: 3 Type: ROUTE-LOOKUP Subtype: Resolve Egress Interface Result: ALLOW Config: Additional Information: found next-hop 192.168.53.235 using egress ifc identity Phase: 4 Type: NAT Subtype: per-session Result: ALLOW Config: Additional Information: Phase: 5 Type: ACCESS-LIST Subtype: Result: DROP Config: Implicit Rule Additional Information: Result: input-interface: G_STAFF_OUTSIDE input-status: up input-line-status: up output-interface: NP Identity Ifc output-status: up output-line-status: up Action: drop Drop-reason: (acl-drop) Flow is denied by configured rule ----------------------------------------------------------- ASA# packet-tracer input G_STAFF_OUTSIDE udp 192.168.53.240 1812 192.168.53.235 1812 detail Phase: 1 Type: CAPTURE Subtype: Result: ALLOW Config: Additional Information: Forward Flow based lookup yields rule: in id=0x7ff04c9202a0, priority=13, domain=capture, deny=false hits=386779, user_data=0x7ff04c403170, cs_id=0x0, l3_type=0x0 src mac=0000.0000.0000, mask=0000.0000.0000 dst mac=0000.0000.0000, mask=0000.0000.0000 input_ifc=G_STAFF_OUTSIDE, output_ifc=any Phase: 2 Type: ACCESS-LIST Subtype: Result: ALLOW Config: Implicit Rule Additional Information: Forward Flow based lookup yields rule: in id=0x7ff04c92d260, priority=1, domain=permit, deny=false hits=26710, user_data=0x0, cs_id=0x0, l3_type=0x8 src mac=0000.0000.0000, mask=0000.0000.0000 dst mac=0000.0000.0000, mask=0100.0000.0000 input_ifc=G_STAFF_OUTSIDE, output_ifc=any Phase: 3 Type: ROUTE-LOOKUP Subtype: Resolve Egress Interface Result: ALLOW Config: Additional Information: found next-hop 192.168.53.235 using egress ifc identity Phase: 4 Type: NAT Subtype: per-session Result: ALLOW Config: Additional Information: Forward Flow based lookup yields rule: in id=0x7ff04b8a6690, priority=0, domain=nat-per-session, deny=true hits=87414063, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0 src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0 input_ifc=any, output_ifc=any Phase: 5 Type: ACCESS-LIST Subtype: Result: DROP Config: Implicit Rule Additional Information: Forward Flow based lookup yields rule: in id=0x7ff04c8c9530, priority=0, domain=permit, deny=true hits=52803, user_data=0xa, cs_id=0x0, use_real_addr, flags=0x1000, protocol=0 src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0 input_ifc=G_STAFF_OUTSIDE, output_ifc=any Result: input-interface: G_STAFF_OUTSIDE input-status: up input-line-status: up output-interface: NP Identity Ifc output-status: up output-line-status: up Action: drop Drop-reason: (acl-drop) Flow is denied by configured rule
Let me start from the beginning:
WIFI controller from network 192.168.53.0/24 with IP 192.168.53.240 should reach RADIUS in 192.168.46.0/24 with IP 192.168.46.250. But request to RADIUS must been from source IP 192.168.46.1 only.
ASA interface in .53.0 - 192.168.53.235
ASA interface in .46.0 - 192.168.46.1
BTW in your example i get error in Access-list phase.
Thank you,
Alex
06-10-2020 11:11 PM
Sia,
Alex
