ASA licensing for HA for 5516-x
LikesEmail15764
Hello everyone.  Im new here, so I hope to be able to do this correctly.  I have two Cisco 5516-x ASAs that I was told need to be setup in HA mode.  I was looking at the licensing, and Im trying to determine if I can do HA with these two with what is currently on there.  My understanding, from what I think I see, is that I can do an active/active setup, but Im not certain that this is what it means.  Can someone verify with me that I can do an HA setup with what this below shows?  And if I wanted to do active/standby, what would I need to purchase to make that happen?  Thank you guys in advance for the help.
5516# sh ver
Cisco Adaptive Security Appliance Software Version 9.8(4)15
Firepower Extensible Operating System Version 2.2(2.121)
Device Manager Version 7.13(1)
Compiled on Thu 14-Nov-19 07:41 PST by builders
System image file is "disk0:/asa984-15-lfbff-k8.SPA"
Config file at boot was "startup-config"
Hardware: ASA5516, 8192 MB RAM, CPU Atom C2000 series 2416 MHz, 1 CPU (8 cores)
Internal ATA Compact Flash, 8000MB
BIOS Flash M25P64 @ 0xfed01000, 16384KB
Encryption hardware device : Cisco ASA Crypto on-board accelerator (revision 0x1)
Number of accelerators: 1
1: Ext: GigabitEthernet1/1 : address is xxxxxxxxxx, irq 255
2: Ext: GigabitEthernet1/2 : address is xxxxxxxxxx, irq 255
3: Ext: GigabitEthernet1/3 : address is xxxxxxxxxx, irq 255
4: Ext: GigabitEthernet1/4 : address is xxxxxxxxxx, irq 255
5: Ext: GigabitEthernet1/5 : address is xxxxxxxxxx, irq 255
6: Ext: GigabitEthernet1/6 : address is xxxxxxxxxx, irq 255
7: Ext: GigabitEthernet1/7 : address is xxxxxxxxxx, irq 255
8: Ext: GigabitEthernet1/8 : address is xxxxxxxxxx, irq 255
9: Int: Internal-Data1/1 : address is xxxxxxxxxx, irq 255
10: Int: Internal-Data1/2 : address is xxxxxxxxxx, irq 0
11: Int: Internal-Control1/1 : address is xxxxxxxxxx, irq 0
12: Int: Internal-Data1/3 : address is xxxxxxxxxx, irq 0
13: Ext: Management1/1 : address is xxxxxxxxxx, irq 0
14: Int: Internal-Data1/4 : address is xxxxxxxxxx, irq 0
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited perpetual
Maximum VLANs : 150 perpetual
Inside Hosts : Unlimited perpetual
Failover : Active/Active perpetual
Encryption-DES : Enabled perpetual
Encryption-3DES-AES : Enabled perpetual
Security Contexts : 2 perpetual
Carrier : Disabled perpetual
AnyConnect Premium Peers : 4 perpetual
AnyConnect Essentials : Disabled perpetual
Other VPN Peers : 300 perpetual
Total VPN Peers : 300 perpetual
AnyConnect for Mobile : Disabled perpetual
AnyConnect for Cisco VPN Phone : Disabled perpetual
Advanced Endpoint Assessment : Disabled perpetual
Shared License : Disabled perpetual
Total TLS Proxy Sessions : 1000 perpetual
Botnet Traffic Filter : Disabled perpetual
Cluster : Enabled perpetual
Cluster Members : 2 perpetual
VPN Load Balancing : Enabled perpetual
Serial Number: XXXXXXXXX
Running Permanent Activation Key:
Configuration register is 0x1
Image type : Release
Key Version : A
Configuration has not been modified since last system restart.
3 Accepted Solutions
balaji.bandi
yes you can do cluster 2 device - with 2 Contexts default.
BB
Your device is already licensed to do both active/active or active/standby, so you don't need any additional licenses to perform an active/standby failover.
You welcome. That's right, having the active/active license would mean the device is licensed for multi-contexts. However, if you have 0 multi-contexts licenses, you device would show active/standby next to the Failover on the show version. In that case, your device can only do active/standby failover, but not active/active.
17 Replies 17
balaji.bandi
As per below output - you have only 2 context License. - you can do 2 context on this HA.
BB
Thank you. Does that mean I can do two physical boxes also?
balaji.bandi
BB
Thank you for your help.
Do you know what license it would take to be able to do active/standby?  I think I would prefer doing that if possible.
Thank you. I did not know it would do active/ standby also. Is that
because it can do active/ active that it can also do active/ standby?
You do not need extra license you already have it.
BB
jiripijacek
i have the question:
i have 2 asa 5508 in HA active/active
Maximum VLANs : 50 perpetual
Other VPN Peers : 100 perpetual
Total VPN Peers : 100 perpetual
Total TLS Proxy Sessions : 320 perpetual
Cluster : Disabled perpetual
Failover cluster licensed features for this platform:
Security Contexts : 4 perpetual
AnyConnect Premium Peers : 8 perpetual
but in context i have AnyConnect Premium Peers :0
and i want to make anyconnect  but debug tell me: Session terminated, no AnyConnect Apex license available
i hope the context inherit the licences. any idea? thank you
Hi @jiripijacek,
When using multi-context, you need to allow usage of VPN whithin a context. For this purpose, you normally create new class, defining restrictions, something like:
class ClassMyContext1
 limit-resource ASDM 5
 limit-resource Telnet 5
 limit-resource Mac-addresses 65535
 limit-resource SSH 5
 limit-resource VPN Other 20
limit-resource VPN AnyConnect 100
After this, you need to add this class to required context:
context MyContext1
 member ClassMyContext1
 allocate-interface Port-channel1.11-Port-channel1.12
 allocate-interface Port-channel1.19
 storage-url private disk0:/MyContext1Disk
 config-url disk0:/MyContext1.cfg
If configuring AnyConnect, you would want to add command 'storage-url private disk0:/MyContext1Disk', as this would create visible disk for your context, where you need to add AnyConnect software and profiles.
BR,
Milos
xxxx-fw-1(config-class)# limit-resource VPN anyConnect 100
ERROR: Cannot set the limit. Total resources required is 200 which exceeds the system capacity of 100
should i switch to anyconnect-essentials?
ciscoasa(config)# webvpn
ciscoasa(config-webvpn)# anyconnect-essentials
I didn't pay attention - you have only 8 AnyCOnnect Premium Peers license. For AnyConnect in multi-context mode, you need to have AnyConnect Apex licenses, which is why you can't switch to AnyConnect Essentials (for which you don't have licenses at all).
Try with 'xxxx-fw-1(config-class)# limit-resource VPN anyConnect 8'
BR,
Milos
