03-12-2007 04:26 PM - edited 03-09-2019 05:35 PM
below is my setup.
business class dsl modem with a static ip (100.0.0.1) connects to a asa5510.
the isp provided me another static routable ip for the asa5510 and I configured the 5510 outside interface with this (100.0.0.2).
I also have couple of machines behind the inside interface of the 5510. (172.16.1.0)
All i want to do is let some ppl vpn into the inside network to do some troubleshooting.
I don't need anyone from the inside to access the net, so no nat needed.
I went through the normal vpn config and the remote vpn wizard.
however, using the cisco vpn client, i'm unable to log in.
I can ping the 100.0.0.1 interface but cannot vpn in.
I think there is no path from 100.0.0.1 to 100.0.0.2
any suggestions?
Solved! Go to Solution.
03-14-2007 08:50 AM
The group name should be EAT which is configured on the tunnel-group parameters in your ASA. It should not be "vgoradia" but what is configured on the ASA.
And the password should be the one that you have configured under the tunnel-group parameter for pre-shared key.
tunnel-group EAT type ipsec-ra
tunnel-group EAT general-attributes
address-pool vpnpool
default-group-policy EAT
tunnel-group EAT ipsec-attributes
pre-shared-key *
Let me know how this pans out.
Rate this post, if it helps.
Gilbert
03-12-2007 05:03 PM
To begin with, do you have a default route on the ASA that points to the DSL? E.g. :
route outside 0.0.0.0 0.0.0.0 100.0.0.1
HTH,
Please rate if it helps,
Kamal
03-12-2007 05:09 PM
nope, do not have a default route set. I need to do this.
when I setup the cisco easyvpn client s/w, the ip I would want to hit is 100.0.0.2 correct?
how would 100.0.0.1 allow traffic to flow to 100.0.0.2?
what command should I use to make 100.0.0.2 pingable temporarily just to verify that the vpn works.
thanks for all the help. i will rate
03-13-2007 02:36 AM
To begin with, are you able to ping 100.0.0.1 from 100.0.0.2? If not then you need to talk to your ISP. You might also want to clear the ARP table on the asa using the CLI command 'clear arp'.
Yes you are correct that the IP you would want to hit is 100.0.0.2. Since 100.0.0.2 is directly connected to 100.0.0.1, it will have .2 IP in its ARP table and will ebe able to route correctly.
Route is important even to be able to ping.
HTH,
Kamal
03-13-2007 07:19 AM
ok I cleared the arp table and put in the static route.
now, from the 5510, i can ping the inside machines using the inside interface and I can ping the outside dsl modem using the outside interface.
Also, from the net, I can now ping the ip for the dsl modem as well as the static routable ip for the asa5510 !!!!!!
this is good.
however, I am unable to vpn into the 5510.
the easyvpn client says 'connection terminated by local client' , reason 412.
I tried to play with the different transport, including checking off and on 'transparent runneling'.
any other ideas?
i'm stumped.
i feel i'm very close to this.
any help would be really appreciated!
03-13-2007 08:30 AM
here's my sh run
ASA Version 7.2(2)
hostname ciscoasa
domain-name default.domain.invalid
enable password xxx
names
interface Ethernet0/0
nameif outside
security-level 0
ip address x.x.80.98 255.255.255.252
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.16.4.231 255.255.252.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_nat0_outbound extended permit ip any 172.16.4.192 255.255.255.192
pager lines 24
logging asdm informational
mtu management 1500
mtu outside 1500
mtu inside 1500
ip local pool vpnpool 172.16.4.220-172.16.4.230 mask 255.255.252.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_nat0_outbound
route outside 0.0.0.0 0.0.0.0 x.x.80.97 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
group-policy EAT internal
group-policy EAT attributes
vpn-tunnel-protocol IPSec
username vgoradia password xxx
privilege 0
username vgoradia attributes
vpn-group-policy EAT
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
address-pool pool
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
03-13-2007 09:05 AM
The config looks good so we need to get debugs from the ASA and the logs from the clients. You might want to remove the PFS from the dynamic cry map. The commands would be :
no crypto map outside_map interface outside
no crypto dynamic-map outside_dyn_map 20 set pfs
HTH,
Please rate if helps,
Kamal
03-13-2007 09:08 AM
what commands do I enable for debugs from the asa and from the client?
thanks
03-13-2007 09:15 AM
On the ASA you would need to run
deb cry isa 128
deb cry ipsec 128
And on the clients, go to the "Log" section
a. Enable Log
b. Go to log settings and change the severity of the logs to 1-3
Open the log window -
Connect and send the logs & debugs.
Gilbert
03-13-2007 09:29 AM
is there a cisco url where I can see a config for a basic remote access vpn on an asa device.
I don't even need to NAT and all the other stuff....
I would've thought that this would be the simplest config of all....
what's compounding the fact is that this device is in a different bldg from where I am and I have to go over everytime to make a change.
and since they do not have a phone line, I have to come back to my office and dial out to an isp and then try to vpn in!!!
(since we do not allow vpn traffic out of our work LAN)
also, is there a way I can manage the asa5510 through it's outside interface since I can ping it?
thanks once again for staying with me.
03-13-2007 10:03 AM
This example gives you an idea on how to configure it.
(Even though it says PIX, it can be used for ASA as well).
Here is another example for VPN client to connect to an ASA and also allow access through the ASA to the internet.
You can access your ASA through the outside interface. You can use ssh or ASDM.
ssh 0.0.0.0 0.0.0.0 outside
Use a "putty client" or some ssh client and you should be able to access the ASA.
Use the username pix which is by default.
Gilbert
Rate this post, if it helped.
03-13-2007 11:49 AM
ok, i modified the settings on the 5510 and still no go.
here's the log from the vpn client.
I could not ssh into the asa from my dial up...and niether could I use the asdm..it just timed out.....
i'm at my wits end!
please help
Cisco Systems VPN Client Version 4.8.02.0010
Copyright (C) 1998-2006 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
Config file directory: C:\Program Files\Cisco Systems\VPN Client
1 14:36:23.545 03/13/07 Sev=Info/6 GUI/0x63B00011
Reloaded the Certificates in all Certificate Stores successfully.
1 14:36:44.915 03/13/07 Sev=Info/4 PPP/0x63200015
Processing enumerate phone book entries command
2 14:36:44.986 03/13/07 Sev=Info/4 PPP/0x6320000D
Retrieved 2 dial entries
3 14:36:56.532 03/13/07 Sev=Info/4 CM/0x63100002
Begin connection process
4 14:36:56.582 03/13/07 Sev=Info/4 CM/0x63100004
Establish secure connection
5 14:36:56.582 03/13/07 Sev=Info/4 CM/0x63100024
Attempt connection with server "x.x.80.98"
6 14:36:56.592 03/13/07 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with x.x.80.98.
7 14:36:56.622 03/13/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Unity)) to x.x.80.98
8 14:36:56.863 03/13/07 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
9 14:36:56.863 03/13/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
10 14:36:56.863 03/13/07 Sev=Info/4 IPSEC/0x6370000D
Key(s) deleted by Interface (x.x.34.170)
11 14:36:56.863 03/13/07 Sev=Info/4 IPSEC/0x6370000D
Key(s) deleted by Interface (x.x.55.131)
12 14:37:01.860 03/13/07 Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
13 14:37:01.860 03/13/07 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to x.x.80.98
14 14:37:06.867 03/13/07 Sev=Info/4 IKE/0x63000021
15 14:37:06.867 03/13/07 Sev=Info/4 IKE/0x63000013
16 14:37:11.874 03/13/07 Sev=Info/4 IKE/0x63000021
17 14:37:11.874 03/13/07 Sev=Info/4 IKE/0x63000013
18 14:37:16.881 03/13/07 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=0D933CECB69B085E R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
19 14:37:17.402 03/13/07 Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=0D933CECB69B085E R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
20 14:37:17.402 03/13/07 Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "x.x.80.98" because of "DEL_REASON_PEER_NOT_RESPONDING"
21 14:37:17.442 03/13/07 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
22 14:37:17.472 03/13/07 Sev=Info/6 CM/0x63100046
Set tunnel established flag in registry to 0.
23 14:37:17.472 03/13/07 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
24 14:37:18.514 03/13/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
25 14:37:18.514 03/13/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
26 14:37:18.514 03/13/07 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
27 14:37:18.514 03/13/07 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
03-13-2007 12:06 PM
Send me the output of the following
sh run ssh
sh cry key mypubkey rsa
from the ASA.
Gilbert
03-13-2007 12:25 PM
here you go...looks like the pubkey is blank.
ciscoasa# sh run ssh
ssh timeout 5
ciscoasa# sh cry key mypubkey rsa
ciscoasa#
03-13-2007 12:29 PM
Issue this command on the ASA
cry key gen rsa modu 1024
Try the ssh again from the client - see if you can access the ASA.
Gilbert
Rate this, if it helps.
