ASA5512-K9 VS ASA5512-MB
Hi all,
I want to know the difference between K9 & MB in the ASA5512-K9 & ASA5512-MB. I want to upload/activate the AnyConnect License on the ASA. Which serial number should be using to get the activation-key? The serial number is different in the both K9 & MB. Which ASA's serial number should I be using? Also, there is a HA pair. While getting the license, I'm receiving error something like Duplicate.
balaji.bandi
Thanks for the reply.
But, the serial number on my CLI of the ASA is of MB after I checked with the #show version command.
The serial number of ASA5512-MB starts with FCHXXXXXXXX.
 While the serial number of ASA5512-K9 starts with FGLXXXXXXXXX.
Also, my ASA's are in HA Pair, so while procuring the AnyConnect License how many devices serial numbers should I add?
can you post-show version and show modules to look.
"Starting with Version 8.3(1), you do not have to have matching licenses on both units. Typically,
you buy a license only for the primary unit; the secondary unit inherits the primary license when it
becomes active"
https://www.cisco.com/c/en/us/td/docs/security/asa/asa96/configuration/general/asa-96-general-config/intro-license.pdf
Any connect FAQ : ( for reference)
https://www.cisco.com/c/en/us/support/docs/security/anyconnect-secure-mobility-client/200191-AnyConnect-Licensing-Frequently-Asked-Qu.html#anc5
BB
