Hello
I have just upgraded the ASA to 9.14(4)24 and ASDM 7.22(1). No issues or drama.
However, it coming clear the MD5 hash is out of Sync between ASDM and the ASA and this is impacting the ASDM's ability to show the Top 120 Access Rules in the main Dashboard but also in the ACL hit counts displayed on the firewall access rules screen. I have validate via the CLI that the counts are present and correctly incrementing on a test environment.
ASA# show access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
alert-interval 300
access-list Outside_access_in; 1 elements; name hash: 0xe796c137
access-list Outside_access_in line 1 extended deny icmp any any inactive (hitcnt=0) (inactive) 0x3b75655e
access-list Inside_access_in; 9 elements; name hash: 0xa231c4d3
access-list Inside_access_in line 1 extended permit ip object VLAN10 any (hitcnt=1055) 0x3b75655e
access-list Inside_access_in line 1 extended permit ip 99.100.10.0 255.255.255.0 any (hitcnt=1055) 0x3b75655e
access-list Inside_access_in line 2 extended deny ip object VLAN20 any time-range KillInternet inactive (hitcnt=0) (inactive) 0x3b75655e
access-list Inside_access_in line 2 extended deny ip 99.100.20.0 255.255.255.0 any time-range KillInternet inactive (hitcnt=0) (inactive) 0x3b75655e
access-list Inside_access_in line 3 extended permit ip object VLAN20 any (hitcnt=502) 0x3b75655e
access-list Inside_access_in line 3 extended permit ip 99.100.20.0 255.255.255.0 any (hitcnt=502) 0x3b75655e
access-list Inside_access_in line 4 extended permit ip object VLAN30 any (hitcnt=250) 0x3b75655e
access-list Inside_access_in line 4 extended permit ip 99.100.30.0 255.255.255.0 any (hitcnt=250) 0x3b75655e
access-list Inside_access_in line 5 extended permit ip object VLAN31 any (hitcnt=0) 0x3b75655e
access-list Inside_access_in line 5 extended permit ip 99.100.31.0 255.255.255.0 any (hitcnt=0) 0x3b75655e
access-list Inside_access_in line 6 extended permit ip object VLAN40 any (hitcnt=141) 0x3b75655e
access-list Inside_access_in line 6 extended permit ip 99.100.40.0 255.255.255.0 any (hitcnt=141) 0x3b75655e
access-list Inside_access_in line 7 extended permit ip object VLAN50 any (hitcnt=0) 0x3b75655e
access-list Inside_access_in line 7 extended permit ip 99.100.50.0 255.255.255.0 any (hitcnt=0) 0x3b75655e
access-list Inside_access_in line 8 extended permit ip object VLAN99 any (hitcnt=61) 0x3b75655e
access-list Inside_access_in line 8 extended permit ip 99.100.99.0 255.255.255.0 any (hitcnt=61) 0x3b75655e
access-list Inside_access_in line 9 extended permit ip 99.100.70.0 255.255.255.0 any (hitcnt=1) 0x3b75655e
I have tried a reboot and not joy, using OpenJRE.bin validated checksum, different devices and dialog boxes confirm ASDM 7.22(1) suspect there is a simple fix and looking for any suggestions or support.
