bandwidth loss using cryptography
fabioportes
i'd like to know how much bandwidth is loss if using a site-to-site vpn with cryptography.
does anybody have an idea ?
thank you very much and i'm sorry for my poor english. :)
Fernando_Meza
Level 7
Level 7
Hi .. I think your question should be in regards of the performance of a device when using encryption for example a PIX 501E provides
■ Maximum clear-text throughput—60 Mbps
■ Maximum throughput (DES)—6 Mbps
■ Maximum throughput (AES-128)—4.5 Mbps
■ Maximum throughput (3DES)—3 Mbps
As you can see it depends of the device you are using and also of the encryption algorithm.
PLease rate it if you find this info helpfull
