basic q:2-crypto maps on the same interface-dynamic
ozgurg
Community Member
hello,
at the moment, i have a crypto-map configured on my outside interface,
where my vpns are defined with each sequence number...
crypto map x ...
crypto map x interface outside
now i want to configure pix for vpn_client
so i create a dynamic-map
crpyo dynamic-map y
and apply it with crypto map interface outside
will this one work ...
as far as i know you can apply only one crypto-map per interface...
Best Regards
5 Replies 5
mklaphek
Level 4
Level 4
You apply the dynamic map to the crypto map with a command like:
crypto map map-name 100 ipsec-isakmp dynamic dynamic-map
You can only apply one crypto map to an interface.
ozgurg
Community Member
what i want to ask is, shortly
can i assign a crypto map (i.e. for site to site vpn) and a dynamic crypto map on the same interface?
TIA
yes you can apply both the site-to-site VPN and a remote VPN map to an interface. They have to have the same crypto map id.
For example:
crypto dynamic-map remote 20 set transform-set vpn3-set
crypto map vpn-map 20 ipsec-isakmp
crypto map vpn-map 20 match address 101
crypto map vpn-map 20 set peer xx.xx.xx.xx
crypto map vpn-map 20 set transform-set vpn3-set
crypto map vpn-map 100 ipsec-isakmp dynamic remote
crypto map vpn-map interface outside
Enjoy
ozgurg
Community Member
in your example,
how is the dynamic map applied to the interface,
with
crypto map vpn-map interface outside...
where as your dynamic map name is remote??
yes exactly!! Sorry about leaving that out.
