Block incoming ports on Cisco 2620 with IOS 12.1 w/FW
it
Can someone tell me a quick and dirty way to block ports on the above mentioned layout? I am trying to avoid access lists if at all possible, because I do not have the time now to fully hash out all needed ports. Basically, I need to be able to block the ports associated with the MSBLAST worm currently going around now, as my router is being flooded on the vulnerable ports. Thanks in advance!
shen.lu
I am using PIX 515 and this is what I did in my firewall associated with the worm.
access-list out2in deny tcp any any eq 4444
access-list out2in deny tcp any any eq 135
access-list out2in deny udp any any eq 69
Yes, I wish the ACL's were that simple on a 2620, but alas, they are not......
