11-21-2003 04:24 AM - edited 03-09-2019 05:37 AM
I tried to solve this with the alias command, but it doesn't work.
Can anyone help me?
http://192.168.144.103 works finde. But http://www.mydomain.com not.
Some informations:
DNS: external from ISP
web-server: 192.168.144.103 (lan-sbs03)
reachable from outside with the ip: xxx.xxx.xxx.8
config:
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xyz encrypted
passwd xyz encrypted
hostname firewall
domain-name xyz
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
name 192.168.144.101 lan-sbs01
name 192.168.144.103 lan-sbs03
name xxx.xxx.xxx.8 out_interface
access-list outside_access_in permit tcp any host out_interface eq www
pager lines 24
logging on
logging buffered debugging
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
icmp deny any echo outside
mtu outside 1500
mtu inside 1500
ip address outside out_interface 255.255.255.128
ip address inside 192.168.144.100 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location lan-sbs01 255.255.255.255 inside
pdm location 192.168.144.49 255.255.255.255 inside
pdm location lan-sbs03 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
alias (inside) lan-sbs03 out_interface 255.255.255.255
static (inside,outside) tcp interface www lan-sbs03 www netmask 255.255.255.25
5 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http lan-sbs01 255.255.255.255 inside
http 192.168.144.49 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
terminal width 80
11-21-2003 04:58 AM
I don't think you can do dns doctoring when using a PAT on the outside interface.
Normally, when using a NATted external address a you can set a static NAT mapping from the outside address to the inside address and limit the access to just the port through the ACL, then the pix sees a DNS reply coming back in for the external address, and alters it to point to your internal address.
You could try putting host table entries on your internal client devices, if there isn't too many.
11-21-2003 05:10 AM
Thx for the quick answer, but I cannot use host table entries because some of the users using notebooks. So they want sometimes have access from inside, sometimes from outside.
Any other solutions?
11-21-2003 05:35 AM
Do you run DNS internally? if so you could add an alias for www for the internal machine name
11-21-2003 05:40 AM
or maybe it could be done on a proxy server's host table, if you have one?
11-21-2003 06:00 AM
If you can not do DNS Doctoring, try using DNAT... it's similar to DNS doctoring, except you swap the locations of the addresses in your command...
11-21-2003 04:46 PM
Since you prefer not to use hosts files, you may want to consider running a DNS server internally that is only accessible for your inside users. You could even make it serve your internal users for your domain information only.
BIND 9 on Linux is one convenient way to do this.
